How is it possible to get autofocus working along with Picamera2 for IMX519
@Edward
This is every command I have run from the point of the fresh install of RaspberryPi 64-bit OS:
   1  dpkg -l | grep libcamera
    2  sudo apt install -y python3-kms++
    3  sudo apt install -y python3-pyqt5 python3-prctl libatlas-base-dev ffmpeg
    4  sudo pip3 install numpy --upgrade
    5  sudo pip3 install picamera2==0.3.2
    6  sudo raspi-config
    7  sudo apt install vim
    8  sudo vim /boot/confi
    9  sudo vim /boot/config.txt
   10  sudo reboot now
   11  git clone https://github.com/raspberrypi/picamera2.git
   12  cd picamera2/examples/
   13  cd ..
   14  git clone https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver.git
   15  ls
   16  cd picamera2/examples/
   17  ls
   18  python3 easy_video.py
   19  cd ..
   20  ls
   21  cd Arducam-Pivariety-V4L2-Driver/
   22  sudo vim /boot/config.txt
   23  sudo reboot now
   24  cd Arducam-Pivariety-V4L2-Driver/focus/
   25  python3 FocuserExample.py -d /dev/v4l-subdev1
   26  sudo apt remove libcamera0
   27  python3 FocuserExample.py -d /dev/v4l-subdev1
   28  python3 FocuserExample.py -d /dev/v4l-subdev0
   29  libcamera-still
   30  ls
   31  cd ..
   32  ls
   33  cd ..
   34  ls
   35  mkdir install
   36  cd install/
   37  wget -O install_pivariety_pkgs.sh https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/install_pivariety_pkgs.sh
   38  chmod +x install_pivariety_pkgs.sh
   39  ./install_pivariety_pkgs.sh -p libcamera_dev
   40  ./install_pivariety_pkgs.sh -p libcamera_apps
   41  vim /boot/config.txt
   42  cat /boot/config.txt
   43  vim /boot/config.txt
   44  sudo vim /boot/config.txt
   45  ls /dev/video/*
   46  ls /dev/video
   47  ls /dev/video*
   48  libcamera-hello
   49  history
   50  history > boot1.txt
   51  sudo reboot now
   52  libcamera-hello
   53  sudo vim /boot/config.txt
   54  sudo reboot now
   55  libcamera-hello
   56  cd Arducam-Pivariety-V4L2-Driver/focus/
   57  python3 FocuserExample.py -d /dev/v4l-subdev1
   58  ls /dev
   59  ls /dev/v4*
   60  python3 FocuserExample.py -d /dev/v4l-subdev0
   61  history
   62  libcamera-hello --autofocus
   63  cd ..
   64  ls
   65  cd src/
   66  ls
   67  cd ../patchs/
   68  ls
   69  cd ../tools/
   70  ls
   71  python3 keyboard_ctrl_tools.py
   72  cd ..
   73  ls
   74  cd focus/
   75  ls
   76  python3 Focuser
   77  python3 FocuserExample.py
   78  python3 FocuserExample.py -d /dev/media3
   79  python3 FocuserExample.py -d /dev/v4l-subdev0
   80  python3 FocuserExample.py -d /dev/v4l-subdev1
   81  python3 FocuserExample.py -d /dev/v4l-subdev2
   82  python3 FocuserExample.py -d /dev/v4l-subdev0
   83  ./install_pivariety_pkgs.sh -p imx519_low_speed_kernel_driver
   84  cd ..
   85  ld
   86  ls
   87  cd install/
   88  ls
   89  ./install_pivariety_pkgs.sh -p imx519_low_speed_kernel_driver
   90  ./install_pivariety_pkgs.sh -p imx519_kernel_driver
   91  libcamera-hello --autofocus
   92  v4l2-ctl -l -d /dev/v4l-subdev0
   93  ls
   94  ./install_pivariety_pkgs.sh -p imx519_low_speed_kernel_driver
   95  ./install_pivariety_pkgs.sh -p imx519_kernel_driver_low_speed
   96  libcamera-hello
   97  libcamera-hello -t 1000000000000
   98  ls
   99  cd picamera2/
  100  ls
  101  cd examples/
  102  ls
  103  python3 easy_video.py
  104  mkdir jp
  105  cp easy_video.py jp/
  106  cd jp/
  107  vim easy_video.py
  108  python3 easy_video.py
  109  ls ../
  110  ls
  111  cat easy_video.py
  112  ls
  113  python3 easy_video.py
  114  vim easy_video.py
  115  cat easy_video.py
  116  python3 easy_video.py
  117  sudo reboot now
  118  sudo apt remove python3-libcamera
  119  clear
Works now
@Edward
This is working now with Autofocus!
#!/usr/bin/python3
picam2 = Picamera2()
picam2.set_controls({"AfTrigger":0})
# Record a 5 second video.
picam2.start_and_record_video("test.mp4", duration=5)
But I’m not sure I totally understand why… Which piece of what I was doing caused the issue?? When I tried to remove python3-libcamera it looked like it said that nothing was removed, but at the same time it seemed that after that things started working… Why would this be?
@trezero
The thing is, libcamera itself is written in C and C++. We packaged him as a dynamic link library so that users can use it in python, and python3-libcamera does the same thing.
Installing python3-libcamera will result in an override that prevents the use of our libcamera, and thus our specific functionality.
picamera2 calls the first layer of wrappers and then makes a new one that is more user friendly.
@Edward whats the proper way to get opencv working with this camera? I noticed that if I do this:
sudo pip3 install opencv-contrib-python==4.5.3.56
Then I end up getting this error
python easy_video.py
Could not write header for output file #0 (incorrect codec parameters ?): Immediate exit requested
If I uninstall opencv everything works again. My goal is to do OCR an utilize other tensor flow recognition utilities. Is there a specific version or method of installing opencv recommended?
@trezero
The data needs to be fetched with picamera2 and then processed with opencv.
If you have no problem with the usage, this is a question you can ask the official.
@Edward I’m not sure I follow your last answer. If the script you sent me requires opencv to be installed, how can this work when after installing opencv the very simple easy_video.py no longer works?
@trezero
easy_video.py
Can I see how it is written?
I can run and give you the version of my environment.
@Edward
#!/usr/bin/python3
picam2.set_controls({“AfTrigger”:0})
picam2.start_and_record_video(“test.mp4”, duration=5)
Should be using opencv-python or opencv-contrib-python?
It seems that the contrib version has a lot of good stuff in it that most people recommend but both seem to cause issues.
@trezero
This is what I use without any problems.
opencv_python==4.6.0.66
picamera2==0.3.2
@Edward I managed to get opencv_python installed. When I try to run python3 real_time.py --model mobilenet_v2.tflite --label coco_labels.txt
I get this error:
[194:16:09.999584747] [85494]  WARN RPI raspberrypi.cpp:1274 Mismatch between Unicam and CamHelper for embedded data usage!
[194:16:10.000859887] [85494] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[194:16:10.001221340] [85494]  INFO RPI raspberrypi.cpp:1398 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media3 and ISP device /dev/media0
Exception in thread Thread-1:
  File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner
    self.run()
  File "/usr/lib/python3.9/threading.py", line 892, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.py", line 22, in thread_func
    self.qpicamera2 = self.make_picamera2_widget(picam2, width=self.width, height=self.height, transform=self.transform)
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.py", line 75, in make_picamera2_widget
    return QGlPicamera2(picam2, width=self.width, height=self.height, transform=self.transform)
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 106, in __init__
    self.init_gl()
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 142, in init_gl
    self.create_surface()
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 136, in create_surface
    surface = eglCreateWindowSurface(self.egl.display, self.egl.config,
  File "/usr/lib/python3/dist-packages/OpenGL/platform/baseplatform.py", line 415, in __call__
    return self( *args, **named )
  File "/usr/lib/python3/dist-packages/OpenGL/error.py", line 230, in glCheckError
    raise self._errorClass(
OpenGL.raw.EGL._errors.EGLError: EGLError(
	err = EGL_BAD_ALLOC,
	baseOperation = eglCreateWindowSurface,
	cArguments = (
		<OpenGL._opaque.EGLDisplay_pointer object at 0x7f790017c0>,
		<OpenGL._opaque.EGLConfig_pointer object at 0x7f79001d40>,
		c_void_p(1),
		None,
	result = <OpenGL._opaque.EGLSurface_pointer object at 0x7f78e09340>
@Edward
Hello, I made a post on github regarding an issue I’m experiencing: Error Attribute Libcamera · Issue #303 · raspberrypi/picamera2 · GitHub
I’ve followed all of the steps you have provided for trezero, but I ended up with the following error message:
AttributeError: type object 'libcamera._libcamera.ColorSpace' has no attribute 'Jpeg'
davidplowman whom I believe is a developer for picamera2 has indicated that the fix for this is to install python3-picamera2. When attempting to install it using:
sudo apt install -y python3-picamera2
I get the following message:
python3-picamera2 : Depends: python3-libcamera but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
You mentioned to not install python3-libcamera as this can lead to conflict. I want to be able to write Python Script and utilize Arducam’s AutoFocus. Currently it looks like I have to pick one or the other. How should I proceed?
@trezero Did you by any chance get this to work?
@trezero
I’m sorry I took a long vacation, real_time. py seems to be the official code, you can submit a lssues at github.
@Alpha-Badger
try first:
sudo apt-get remove --purge python3-picamera2
If you want to use autofocus, you must use our libcamera.
We have recently updated libcamera, you need to update our libcamera to resolve this issue.
Is picam2.set_controls({“AfModeContinuous”:0}) working for anyone?
I’m getting a runtime error:
control AfModeContinuous is not advertied by libcamera
I can’t find reference to this error anywhere on the web
I did the recent libcamera update mentioned in the above reply and got this at the end:
W: Repository is broken: Libcamera-apps:armhf (= 0.0.9) has no Size information
Is this normal?
Okay it looks like the afTrigger is working as a continuous auto focus but only refocuses with an object really close like 2" away.
Using:
picam2.set_controls({“AFTrigger”:1})
What does the The numeric after AFTrigger control?
@ZEROTYPE
Don’t worry, we set the size the same internally.
Should use picam2.set_controls({“AFTrigger”:0})
https://github.com/edward-ardu/picamera2_example/blob/main/Autofocus_control.py
Official Explanation
https://libcamera.org/api-html/namespacelibcamera_1_1controls.html#a4e2c54ebb9dd200e458aea7632404f4a
Interesting, it seems to be refocusing more when set to 1.
Have the AF modes been cut?
What controls are available through set_controls in your version of libcamera?
Is there any way to tune the auto focus through python?
@ZEROTYPE
This seems to be a bug , I will debug it.
You can print it out by following
controls = picam2.camera_controls
print(controls)
What do you mean by that and can you elaborate on it? Are you trying to manually control the focal length?
