How do you handle multi camera detection and functionality on windows 11?
  1. I got 17 Arducam Cameras from Amazon
  2. Model is IMX 519 with the USB3 shield
  3. Windows 11 system with Asus ProArt Z790 motherboard. Two USB expansion cards PCE7USB-R05 VER006
  4. Tried pretty much everything i could, but the system chaotically chooses to drop many cameras to USB2 protocol and therefore the lowest resolution available, not detect some cameras at all, cameras just freezing and not working etc. The best results i can get sometimes, is through unplugging and re-plugging each camera, one at a time. This is not optimal. The system needs to be ready and working from boot without any human intervention.
Could plugging three StarTech PEXUSB3S44V to take most of the load, solve the problem? At this point i can say the system reliably detects only 4 cameras after rebooting I’d hate to push my luck with any more.
Any suggestions?
Hi there,
Could you show me the link to the product you purchased?
Here it is.
Thanks. Got it!
There are two primary factors that you must manage for a stable multi-camera system on a single host computer:
  1. Sufficient Power: Each USB camera draws power from the port. When multiple cameras are running, especially high-resolution ones, the combined power draw can exceed what a standard motherboard’s internal USB hub can reliably supply, leading to instability.
  2. USB Bandwidth: This is the most common bottleneck. A single USB 3.0 host controller on a motherboard shares a limited amount of bandwidth (typically 5Gbps) across several ports. One camera can easily consume a large portion of this bandwidth, and running multiple cameras at once will quickly saturate the controller, causing dropped frames or preventing cameras from initializing.
Your research into a card like the StarTech PEXUSB3S44V points to the correct solution. High-quality PCIe expansion cards often solve both problems by providing dedicated host controllers for each port or for pairs of ports. This gives each camera its own “private lane” for data and ensures a more stable power supply.
To be perfectly clear, we have not officially tested that specific StarTech card in our labs, so we cannot guarantee its performance. However, your approach is correct, and trying a card like this is a very logical next step.
We hope this information is helpful
