Hi!
I followed the steps listed here: 3.2 V4L2 OBISP Driver Installation & Uninstallation - Arducam to download the kernel driver in order to properly use my Arducam with Raspberry Pi 4. But when testing the camera with arducamstill -t 0 i get the following message:
Hardware version: d03114
No match to hardware version!
Error opnenig device.
arducamVideoInit failed.
Unable to set format: Bad file descriptor (9)
Does this have to do with the driver I´m using, or could it be something else?
When following the steps from the first link, after ./install_pivariety_pkgs.sh -p kernel_driver I get the following message:
Cannot find the corresponding package, please send the flollowing information to support@arducam
Hardware revision: d03114
Kernel Version: 5.4.79-v71+
Package: kernel_driver – bullseye-v5
You are using an unsupported kernel version, please install the official SD card image (do not execute rpi-update)
I also tried the “You can also follow the step to install the driver by yourself” way and it isn’t working either. Apparently the driver is trying to stat the files arducam.ko and arducam.dbto at bin/5.4.79-v71+ and they don’t exist. But I see files with those same names at bin/5.10.xx-vxx+ (the x’s taking different values)
I upgraded the kernel (now it says 5.15.61-v7l), but when executing install_driver.sh it keeps returning the same message (./bin/5.15.61-v7l+/arducam.ko does not exist). Is it too new now?
