OV2311
Jetson NX
quit working
Hi, I’m using two OV2311 mipi cameras with Jetson NX connected on develop kit(with R32.4.3) mipi port. I want to get two camera frame by hardware trigger at same time. I used C++ and python with OpenCV 4 and threading to get frame.
I can set every config I want and is working fine with program start in free run.
But when I set trigger mode to the Hardware trigger, I saw something error.
First, after I change mode to HW trigger, it will get last frame after timeout.(I think is OpenCV buffer issue, because your website mentions that.), so I used OPenCV cap.read() func serval times to clear buffer before I start trigger. It’s workaround but is there any solution to solve that because the buffer count is not same every time.
Second, after serval times hardware-trigge about 10 Hz and trigger 20 times on one loop. Got frame fine at start but failed after about 50 times loop. The error message shows
[ 三 23 09:34] arducam-csi2: arducam_s_ctrl: cid = (0x980911), value = (3000).
[ +0.033222] arducam-csi2: arducam_s_ctrl: cid = (0x981902), value = (1).
[ +0.024985] arducam-csi2: arducam_s_ctrl: cid = (0x981901), value = (1).
[ +0.024546] arducam-csi2: arducam_s_ctrl: cid = (0x980911), value = (3000).
[ +0.026206] arducam-csi2: arducam_s_ctrl: cid = (0x981902), value = (1).
[ +0.023257] arducam-csi2: arducam_s_ctrl: cid = (0x981901), value = (1).
[ +2.624907] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000196] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000156] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000195] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000116] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000148] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.002106] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.001743] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.555270] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000012] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000016] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000018] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000526] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000187] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.002511] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.000220] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.556473] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000165] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000175] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000161] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000140] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000200] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.006639] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.000188] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.552284] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000157] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000171] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000154] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000115] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000212] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.004807] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.000187] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.554164] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000158] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000155] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000158] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000114] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000143] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.002524] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.000285] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.556405] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000011] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000019] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000557] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000163] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.001627] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.001495] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +2.556069] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000027] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000549] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000166] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.003970] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +0.000163] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +9.722926] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000006] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000015] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.000015] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ +0.000535] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ +0.001589] channel context at 0 is busy
[ +0.000065] ------------[ cut here ]------------
[ +0.000113] WARNING: CPU: 3 PID: 12143 at /home/wang/Arducam/Jetson/l4t-32.4.3-NX/Linux_for_Tegra/source/public/kernel_src/kernel/nvidia/drivers/platform/tegra/rtcpu/capture-ivc.c:229 tegra_capture_ivc_notify_chan_id+0x184/0x1a0
[ +0.000355] Modules linked in: fuse zram overlay bnep rtk_btusb btusb btrtl btbcm btintel cdc_acm spidev rtl8822ce cfg80211 nvgpu bluedroid_pm ip_tables x_tables
[ +0.000095] CPU: 3 PID: 12143 Comm: vi-output, ardu Not tainted 4.9.140-tegra #6
[ +0.000005] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ +0.000006] task: ffffffc1f29c0000 task.stack: ffffffc082cc4000
[ +0.000008] PC is at tegra_capture_ivc_notify_chan_id+0x184/0x1a0
[ +0.000005] LR is at tegra_capture_ivc_notify_chan_id+0x184/0x1a0
[ +0.000006] pc : [<ffffff8008c9cc34>] lr : [<ffffff8008c9cc34>] pstate: 60c00045
[ +0.000004] sp : ffffffc082cc7b00
[ +0.000005] x29: ffffffc082cc7b00 x28: 0000000000000000
[ +0.000011] x27: ffffffc1f100e048 x26: ffffff8027aee000
[ +0.000011] x25: 0000000000001043 x24: ffffffc1f0e3e020
[ +0.000010] x23: 0000000000000000 x22: ffffffc1f0e3e818
[ +0.000010] x21: 0000000000000040 x20: 0000000000000800
[ +0.000010] x19: ffffffc1f0e3e018 x18: 0000000000000000
[ +0.000011] x17: 0000007f839ea0a0 x16: 0000000000000000
[ +0.000009] x15: ffffffffffffffff x14: ffffff800a15a1e0
[ +0.000010] x13: ffffff800a159e14 x12: 0000000000000000
[ +0.000010] x11: 0000000000000400 x10: 00000000000012b7
[ +0.000012] x9 : ffffffc082cc7900 x8 : 20747865746e6f63
[ +0.000010] x7 : 206c656e6e616863 x6 : ffffff800a1590bc
[ +0.000010] x5 : 0000000000000000 x4 : 0000000000000000
[ +0.000010] x3 : ffffffffffffffff x2 : 00000041f6520000
[ +0.000010] x1 : ffffffc1f29c0000 x0 : 000000000000001c
[ +0.000014] —[ end trace eccd79b24b613449 ]—
[ +0.000111] Call trace:
[ +0.000009] [<ffffff8008c9cc34>] tegra_capture_ivc_notify_chan_id+0x184/0x1a0
[ +0.000010] [<ffffff8008b4a5e8>] vi_capture_setup+0x340/0x4d0
[ +0.000007] [<ffffff8008b4be60>] tegra_channel_capture_setup+0xf0/0x228
[ +0.000006] [<ffffff8008b4cf90>] vi5_channel_error_recover+0x108/0x1d8
[ +0.000009] [<ffffff8008b41b58>] tegra_channel_error_recover+0x58/0x90
[ +0.000007] [<ffffff8008b4c79c>] tegra_channel_kthread_capture_dequeue+0x26c/0x4a8
[ +0.000008] [<ffffff80080dbe64>] kthread+0xec/0xf0
[ +0.000008] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[ +0.000041] tegra194-vi5 15c10000.vi: failed to update control callback
[ +0.005553] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ +1.015072] tegra194-vi5 15c10000.vi: no reply from camera processor
[ +0.000183] tegra194-vi5 15c10000.vi: vi capture setup failed
[ +0.000133] tegra194-vi5 15c10000.vi: fatal: error recovery failed
[ +0.343522] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ +0.000218] Mem abort info:
[ +0.000057] ESR = 0x96000005
[ +0.000095] Exception class = DABT (current EL), IL = 32 bits
[ +0.000114] SET = 0, FnV = 0
[ +0.000060] EA = 0, S1PTW = 0
[ +0.000059] Data abort info:
[ +0.000056] ISV = 0, ISS = 0x00000005
[ +0.000073] CM = 0, WnR = 0
[ +0.000064] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc09ffbb000
[ +0.000150] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ +0.000154] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ +0.000101] Modules linked in: fuse zram overlay bnep rtk_btusb btusb btrtl btbcm btintel cdc_acm spidev rtl8822ce cfg80211 nvgpu bluedroid_pm ip_tables x_tables
[ +0.000418] CPU: 1 PID: 12178 Comm: Camera_Show Tainted: G W 4.9.140-tegra #6
[ +0.000509] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ +0.000499] task: ffffffc0d6e18e00 task.stack: ffffffc15f8cc000
[ +0.000482] PC is at exit_creds+0x2c/0x78
[ +0.001630] LR is at __put_task_struct+0x4c/0x140
[ +0.004895] pc : [<ffffff80080deefc>] lr : [<ffffff80080b012c>] pstate: 60400045
[ +0.007437] sp : ffffffc15f8cfa10
[ +0.003412] x29: ffffffc15f8cfa10 x28: 0000000000000008
[ +0.005422] x27: ffffff8008f72000 x26: ffffffc15f8cfde8
[ +0.005599] x25: ffffffc168123168 x24: ffffffc1f0dfe278
[ +0.005250] x23: 0000000000000001 x22: ffffffc1f297c018
[ +0.005250] x21: ffffffc1f29c0030 x20: 0000000000000000
[ +0.005338] x19: ffffffc1f29c0000 x18: 0000000000000400
[ +0.005526] x17: 000000000000000e x16: 0000000000000000
[ +0.005688] x15: 0000000000000336 x14: 0000000000000df2
[ +0.005935] x13: 00000000000012be x12: 000000000000082f
[ +0.005512] x11: 0000000000000000 x10: 0000000000000a10
[ +0.005526] x9 : ffffffc15f8cf860 x8 : ffffffc0d6e19870
[ +0.005774] x7 : 0000000000000001 x6 : 000000125800bee4
[ +0.003248] x5 : 0000000000000800
[ +0.000003] x4 : 0000000000000000
[ +0.000009] x3 : 00000000000000c2 x2 : 0000000000000000
[ +0.000007] x1 : 0000000000000000 x0 : 00000000ffffffff
[ +0.000027] Process Camera_Show (pid: 12178, stack limit = 0xffffffc15f8cc000)
[ +0.000003] Call trace:
[ +0.000015] [<ffffff80080deefc>] exit_creds+0x2c/0x78
[ +0.000008] [<ffffff80080b012c>] __put_task_struct+0x4c/0x140
[ +0.000006] [<ffffff80080dc9bc>] kthread_stop+0x1e4/0x1e8
[ +0.000008] [<ffffff8008b4c030>] vi5_channel_stop_kthreads+0x40/0x58
[ +0.000012] [<ffffff8008b4c0d4>] vi5_channel_stop_streaming+0x8c/0xa8
[ +0.000007] [<ffffff8008b3ea04>] tegra_channel_stop_streaming+0x34/0x48
[ +0.000006] [<ffffff8008b36d14>] __vb2_queue_cancel+0x34/0x188
[ +0.000005] [<ffffff8008b3823c>] vb2_core_queue_release+0x2c/0x58
[ +0.000004] [<ffffff8008b3a8bc>] _vb2_fop_release+0x84/0xa0
[ +0.000006] [<ffffff8008b403b4>] tegra_channel_close+0x64/0x140
[ +0.000007] [<ffffff8008b13e70>] v4l2_release+0x48/0xa0
[ +0.000007] [<ffffff800825ebd0>] __fput+0x90/0x1d0
[ +0.000005] [<ffffff800825ed88>] ____fput+0x20/0x30
[ +0.000008] [<ffffff80080d9b74>] task_work_run+0xbc/0xd8
[ +0.000007] [<ffffff80080b95f4>] do_exit+0x2c4/0xa08
[ +0.000005] [<ffffff80080b9dc8>] do_group_exit+0x40/0xa8
[ +0.000006] [<ffffff80080c76c4>] get_signal+0x26c/0x578
[ +0.000007] [<ffffff800808b150>] do_signal+0x130/0x500
[ +0.000005] [<ffffff800808b698>] do_notify_resume+0x90/0xb0
[ +0.000005] [<ffffff800808379c>] work_pending+0x8/0x10
[ +0.000009] —[ end trace eccd79b24b61344a ]—
[ +0.012910] Fixing recursive fault but reboot is needed!
nvidia@nx:~/project/solscan_linux/build$ v4l2-ctl -d 0 -l
User Controls
exposure 0x00980911 (int) : min=0 max=65535 step=1 default=1466 value=3000
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=0
trigger_mode 0x00981901 (bool) : default=0 value=1
disable_frame_timeout 0x00981902 (bool) : default=0 value=1
frame_timeout 0x00981903 (int) : min=100 max=12000 step=1 default=2000 value=2000
Camera Controls
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
Is there anything setting can help? Because after that I can’t control camera and only can reboot Jetson NX.
