Aducam -
B0388 -
Raspberry Pi Zero 2 W -
Online Manual -
We successfully have 6 Quad Hats working with RPi Zero 2 Ws. However, I cannot get 3 Quad hats to work. One of the three works only with cameras 2 and 3, and two of the devices work with no cameras in any relevant setting (0x00, 0x02, 0x12, 0x22, 0x32). Help!!! -
Pasted below. -
Swapped cameras, swapped cables, swapped RPis, reinstalled OS and pivariety drivers. -
We are about to deploy our project, and we need those three dead Quad Hats to work!!! Perhaps there is a software fix or hardware fix that we can perform. Perhaps we were very unlucky and have bad units…
[ 0.000000] Linux version 5.15.84-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 11:59:48 GMT 2023
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero 2 W Rev 1.0
[ 0.000000] Reserved memory: created CMA memory pool at 0x0bc00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35724 r8192 d21620 u65536
[ 0.000000] pcpu-alloc: s35724 r8192 d21620 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=B8:27:EB:5A:55:0E vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=7dad7879-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 173988K/458752K available (10240K kernel code, 1337K rwdata, 3076K rodata, 1024K init, 569K bss, 22620K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 33312 entries in 98 pages
[ 0.000000] ftrace: allocated 98 pages with 3 groups
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000023] Switching to timer-based delay loop, resolution 52ns
[ 0.000418] Console: colour dummy device 80x30
[ 0.001219] printk: console [tty1] enabled
[ 0.001293] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[…] Snipped
[ 0.255290] simple-framebuffer 1e402000.framebuffer: framebuffer at 0x1e402000, 0x7f8000 bytes
[ 0.255344] simple-framebuffer 1e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.291093] Console: switching to colour frame buffer device 240x67
[ 0.324331] simple-framebuffer 1e402000.framebuffer: fb0: simplefb registered!
[ 0.335855] NET: Registered PF_INET protocol family
[ 0.336267] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.337853] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.338149] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.338397] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.338702] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.339011] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.339346] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.339578] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.340072] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.343779] RPC: Registered named UNIX socket transport module.
[ 0.343973] RPC: Registered udp transport module.
[ 0.344124] RPC: Registered tcp transport module.
[ 0.344273] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.882872] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.922500] Initialise system trusted keyrings
[ 1.923113] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.933464] zbud: loaded
[ 1.935772] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.936965] NFS: Registering the id_resolver key type
[ 1.937182] Key type id_resolver registered
[ 1.937321] Key type id_legacy registered
[ 1.937596] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.937805] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.939322] Key type asymmetric registered
[ 1.939464] Asymmetric key parser ‘x509’ registered
[ 1.939706] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.939935] io scheduler mq-deadline registered
[ 1.940082] io scheduler kyber registered
[ 1.950869] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.951637] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.962034] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.983698] brd: module loaded
[ 2.003061] loop: module loaded
[ 2.012852] Loading iSCSI transport class v2.0-870.
[ 2.023703] usbcore: registered new interface driver lan78xx
[ 2.032539] usbcore: registered new interface driver smsc95xx
[ 2.041216] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.778157] Core Release: 2.80a
[ 2.786749] Setting default values for core params
[ 2.795351] Finished setting default values for core params
[ 3.004322] Using Buffer DMA mode
[ 3.012947] Periodic Transfer Interrupt Enhancement - disabled
[ 3.021700] Multiprocessor Interrupt Enhancement - disabled
[ 3.030434] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.039223] Dedicated Tx FIFOs mode
[ 3.049255] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 8bd04000 dma = 0xcbd04000 len=9024
[ 3.066603] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.109575] dwc_otg: Microframe scheduler enabled
[ 3.109714] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.126676] WARN::hcd_init_fiq:458: FIQ ASM at 807fc54c length 36
[ 3.143543] WARN::hcd_init_fiq:497: MPHI regs_base at 9c810000
[ 3.160205] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.168546] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.176923] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.185193] Init: Port Power? op_state=1
[ 3.193360] Init: Power Port (0)
[ 3.201716] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.209888] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.218021] usb usb1: Product: DWC OTG Controller
[ 3.226090] usb usb1: Manufacturer: Linux 5.15.84-v7+ dwc_otg_hcd
[ 3.234121] usb usb1: SerialNumber: 3f980000.usb
[ 3.242958] hub 1-0:1.0: USB hub found
[ 3.250890] hub 1-0:1.0: 1 port detected
[ 3.259656] dwc_otg: FIQ enabled
[ 3.259670] dwc_otg: NAK holdoff enabled
[ 3.259683] dwc_otg: FIQ split-transaction FSM enabled
[ 3.259702] Module dwc_common_port init
[ 3.260087] usbcore: registered new interface driver usb-storage
[ 3.268271] mousedev: PS/2 mouse device common for all mice
[ 3.279743] sdhci: Secure Digital Host Controller Interface driver
[ 3.287841] sdhci: Copyright(c) Pierre Ossman
[ 3.296428] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.305840] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.314115] hid: raw HID events driver (C) Jiri Kosina
[ 3.322176] usbcore: registered new interface driver usbhid
[ 3.330056] usbhid: USB HID core driver
[ 3.343863] Initializing XFRM netlink socket
[ 3.351825] NET: Registered PF_PACKET protocol family
[ 3.359881] Key type dns_resolver registered
[ 3.368414] Registering SWP/SWPB emulation handler
[ 3.377028] registered taskstats version 1
[ 3.385046] Indeed it is in host mode hprt0 = 00041901
[ 3.392877] Loading compiled-in X.509 certificates
[ 3.453449] Key type .fscrypt registered
[ 3.461125] Key type fscrypt-provisioning registered
[ 3.480970] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.488996] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.499846] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.508168] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.517848] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.525675] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.560579] sdhost: log_buf @ 2869e2f6 (cbd03000)
[ 3.602741] usb 1-1: new low-speed USB device number 2 using dwc_otg
[ 3.611632] Indeed it is in host mode hprt0 = 00041901
[ 3.617455] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.630270] of_cfs_init
[ 3.638407] of_cfs_init: OK
[ 3.647478] Waiting for root device PARTUUID=7dad7879-02…
[ 3.687686] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.699514] mmc0: new high speed SDHC card at address 5048
[ 3.708764] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[ 3.721780] mmcblk0: p1 p2
[ 3.730525] mmcblk0: mmc0:5048 SD32G 29.7 GiB (quirks 0x00004000)
[ 3.765061] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.773513] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.781496] mmc1: new high speed SDIO card at address 0001
[ 3.790606] devtmpfs: mounted
[ 3.806913] Freeing unused kernel image (initmem) memory: 1024K
[ 3.815554] Run /sbin/init as init process
[ 3.823724] with arguments:
[ 3.823737] /sbin/init
[ 3.823749] with environment:
[ 3.823760] HOME=/
[ 3.823771] TERM=linux
[ 3.868350] usb 1-1: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.78
[ 3.876926] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.885432] usb 1-1: Product: Dell USB Entry Keyboard
[ 3.893892] usb 1-1: Manufacturer: DELL
[ 3.908828] input: DELL Dell USB Entry Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0001/input/input0
[ 3.983587] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-3f980000.usb-1/input0
[ 4.340622] systemd[1]: System time before build time, advancing clock.
[ 4.617581] NET: Registered PF_INET6 protocol family
[ 4.628192] Segment Routing with IPv6
[ 4.637051] In-situ OAM (IOAM) with IPv6
[ 4.733322] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.753793] systemd[1]: Detected architecture arm.
[ 4.807239] systemd[1]: Set hostname to .
[ 5.935977] systemd[1]: Queued start job for default target Multi-User System.
[ 5.953630] systemd[1]: Created slice system-getty.slice.
[ 5.976504] systemd[1]: Created slice system-modprobe.slice.
[ 5.999215] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 6.021652] systemd[1]: Created slice User and Session Slice.
[ 6.043446] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.065381] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.088713] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.111611] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.134788] systemd[1]: Reached target Paths.
[ 6.157589] systemd[1]: Reached target Slices.
[ 6.180314] systemd[1]: Reached target Swap.
[ 6.210466] systemd[1]: Listening on Syslog Socket.
[ 6.234036] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.257109] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.281233] systemd[1]: Listening on Journal Audit Socket.
[ 6.304988] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.329296] systemd[1]: Listening on Journal Socket.
[ 6.367498] systemd[1]: Listening on udev Control Socket.
[ 6.391707] systemd[1]: Listening on udev Kernel Socket.
[ 6.415934] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 6.432100] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.461386] systemd[1]: Mounting RPC Pipe File System…
[ 6.491222] systemd[1]: Mounting Kernel Debug File System…
[ 6.521060] systemd[1]: Mounting Kernel Trace File System…
[ 6.545648] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 6.564224] systemd[1]: Starting Restore / save the current clock…
[ 6.594735] systemd[1]: Starting Set the console keyboard layout…
[ 6.625553] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 6.658101] systemd[1]: Starting Load Kernel Module configfs…
[ 6.688918] systemd[1]: Starting Load Kernel Module drm…
[ 6.719084] systemd[1]: Starting Load Kernel Module fuse…
[ 6.752352] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.768802] systemd[1]: Starting File System Check on Root Device…
[ 6.801760] fuse: init (API version 7.34)
[ 6.835386] systemd[1]: Starting Journal Service…
[ 6.894592] systemd[1]: Starting Load Kernel Modules…
[ 6.936469] systemd[1]: Starting Coldplug All udev Devices…
[ 6.980196] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.987542] i2c_dev: i2c /dev entries driver
[ 7.018719] systemd[1]: Mounted RPC Pipe File System.
[ 7.051415] systemd[1]: Mounted Kernel Debug File System.
[ 7.073997] systemd[1]: Mounted Kernel Trace File System.
[ 7.097957] systemd[1]: Finished Restore / save the current clock.
[ 7.133562] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 7.158076] systemd[1]: [email protected]: Succeeded.
[ 7.170069] systemd[1]: Finished Load Kernel Module configfs.
[ 7.193504] systemd[1]: Started Journal Service.
[ 7.582587] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 7.671730] systemd-journald[136]: Received client request to flush runtime journal.
[ 7.694219] systemd-journald[136]: File /var/log/journal/543e5707b73649fa8eca561bc40fac05/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 9.391421] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.395345] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 9.395404] [vc_sm_connected_init]: start
[ 9.397074] [vc_sm_connected_init]: installed successfully
[ 9.438689] mc: Linux media interface: v0.10
[ 9.631344] videodev: Linux video capture interface: v2.00
[ 9.724602] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.726730] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.729218] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[ 9.771390] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.779062] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.787193] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 9.787272] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 9.790763] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 9.790836] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 9.796475] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 9.796537] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.799628] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 9.799695] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 9.809729] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 9.809966] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 9.815358] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.853033] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.900202] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 9.900725] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 9.901145] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 9.901503] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 9.901548] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 9.901592] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 9.901617] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 9.901639] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 9.910253] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 9.910813] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 9.911301] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 9.911667] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 9.911707] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 9.911736] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 9.911759] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 9.911781] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 9.912026] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 10.143172] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.355996] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 10.374056] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 10.764624] brcmfmac: F1 signature read @0x18000000=0x1542a9a6
[ 10.794092] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436-sdio for chip BCM43430/2
[ 10.795062] usbcore: registered new interface driver brcmfmac
[ 11.000074] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436-sdio for chip BCM43430/2
[ 11.032614] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/2 wl0: Mar 31 2022 17:24:51 version 9.88.4.77 (g58bc5cc) FWID 01-3b307371
[ 11.287853] checking generic (1e402000 7f8000) vs hw (0 ffffffff)
[ 11.287896] fb0: switching to vc4 from simple
[ 11.317928] Console: switching to colour dummy device 80x30
[ 11.332161] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 11.345503] Registered IR keymap rc-cec
[ 11.345771] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 11.346061] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input1
[ 11.366576] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 11.367216] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 11.367676] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.368154] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.368599] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.368992] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 11.421883] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 11.615715] Console: switching to colour frame buffer device 240x67
[ 11.655306] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 12.330101] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 12.366456] uart-pl011 3f201000.serial: no DMA platform data
[ 13.305124] 8021q: 802.1Q VLAN Support v1.8
[ 13.567868] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 14.906162] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 18.194900] Bluetooth: Core ver 2.22
[ 18.195044] NET: Registered PF_BLUETOOTH protocol family
[ 18.195054] Bluetooth: HCI device and connection manager initialized
[ 18.195638] Bluetooth: HCI socket layer initialized
[ 18.195655] Bluetooth: L2CAP socket layer initialized
[ 18.195682] Bluetooth: SCO socket layer initialized
[ 18.274438] Bluetooth: HCI UART driver ver 2.3
[ 18.274467] Bluetooth: HCI UART protocol H4 registered
[ 18.274566] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.275566] Bluetooth: HCI UART protocol Broadcom registered
[ 18.831534] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.831560] Bluetooth: BNEP filters: protocol multicast
[ 18.831584] Bluetooth: BNEP socket layer initialized
[ 18.870310] NET: Registered PF_ALG protocol family
[ 18.926380] cryptd: max_cpu_qlen set to 1000
[ 33.752775] cam-dummy-reg: disabling
[ 474.334773] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/status
[ 474.334819] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@7e205000/status
[ 474.403378] i2c i2c-11: Added multiplexed i2c bus 0
[ 474.403723] i2c i2c-11: Added multiplexed i2c bus 10
[ 474.563672] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@7e804000/status
[ 493.322699] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/i2c@1/status
[ 493.322824] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/csi@7e801000/status
[ 493.322845] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/csi@7e801000/brcm,media-controller
[ 493.322913] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@7e205000/status
[ 493.322935] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /cam1_clk/clock-frequency
[ 493.322953] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /cam1_clk/status
[ 493.322972] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c0mux/status
[ 493.343974] platform 3f801000.csi: Fixing up cyclic dependency with 10-001a
[ 493.632088] imx519: loading out-of-tree module taints kernel.
[ 493.644504] imx519 10-001a: Device found is imx519
[ 493.644734] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 514.192834] imx519 10-001a: Failed to write reg 0x3f7f. error = -5
[ 514.192861] imx519 10-001a: imx519_start_streaming failed to set common settings
[ 514.192880] unicam 3f801000.csi: stream on failed in subdev
[ 514.198650] ------------[ cut here ]------------
[ 514.198660] WARNING: CPU: 1 PID: 4985 at drivers/media/mc/mc-entity.c:573 __media_pipeline_stop+0xe4/0xe8 [mc]
[ 514.198718] Modules linked in: ak7375(O) imx519(O) bcm2835_unicam v4l2_dv_timings v4l2_fwnode v4l2_async i2c_mux_pinctrl i2c_mux cmac algif_hash aes_arm_bs crypto_simd cryptd algif_skcipher af_alg bnep hci_uart btbcm bluetooth ecdh_generic ecc 8021q garp stp llc spidev vc4 brcmfmac snd_soc_hdmi_codec cec drm_kms_helper brcmutil sha256_generic snd_soc_core cfg80211 snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops raspberrypi_hwmon bcm2835_isp(C) bcm2835_v4l2(C) videobuf2_vmalloc bcm2835_codec(C) v4l2_mem2mem snd_bcm2835(C) bcm2835_mmal_vchiq(C) videobuf2_dma_contig rfkill videobuf2_memops videobuf2_v4l2 videobuf2_common snd_pcm videodev i2c_bcm2835 snd_timer snd mc vc_sm_cma(C) spi_bcm2835 uio_pdrv_genirq uio fixed i2c_dev drm fuse drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
[ 514.199223] CPU: 1 PID: 4985 Comm: libcamera-still Tainted: G C O 5.15.84-v7+ #1613
[ 514.199234] Hardware name: BCM2835
[ 514.199240] Backtrace:
[ 514.199248] [<80a47ec8>] (dump_backtrace) from [<80a48110>] (show_stack+0x20/0x24)
[ 514.199273] r7:0000023d r6:80d19fc0 r5:00000000 r4:60000013
[ 514.199278] [<80a480f0>] (show_stack) from [<80a4c6dc>] (dump_stack_lvl+0x70/0x94)
[ 514.199297] [<80a4c66c>] (dump_stack_lvl) from [<80a4c718>] (dump_stack+0x18/0x1c)
[ 514.199318] r7:0000023d r6:00000009 r5:7f1953a8 r4:7f198bac
[ 514.199324] [<80a4c700>] (dump_stack) from [<80120b30>] (__warn+0xfc/0x114)
[ 514.199342] [<80120a34>] (__warn) from [<80a486c8>] (warn_slowpath_fmt+0x70/0xd8)
[ 514.199360] r7:0000023d r6:7f198bac r5:81005008 r4:00000000
[ 514.199365] [<80a4865c>] (warn_slowpath_fmt) from [<7f1953a8>] (__media_pipeline_stop+0xe4/0xe8 [mc])
[ 514.199418] r9:826cc50c r8:00000001 r7:7f1b5140 r6:826cc3ac r5:00000004 r4:00000000
[ 514.199423] [<7f1952c4>] (__media_pipeline_stop [mc]) from [<7f1953dc>] (media_pipeline_stop+0x30/0x3c [mc])
[ 514.199502] r9:826cc50c r8:00000001 r7:7f1b5140 r6:826cc3ac r5:826cc520 r4:826cc16c
[ 514.199507] [<7f1953ac>] (media_pipeline_stop [mc]) from [<7f58d98c>] (unicam_stop_streaming+0x94/0x164 [bcm2835_unicam])
[ 514.199573] r5:826cc000 r4:826cc290
[ 514.199577] [<7f58d8f8>] (unicam_stop_streaming [bcm2835_unicam]) from [<7f2844e4>] (__vb2_queue_cancel+0x38/0x258 [videobuf2_common])
[ 514.199651] r7:7f1b5140 r6:826cc3ac r5:85b34300 r4:826cc3ac
[ 514.199656] [<7f2844ac>] (__vb2_queue_cancel [videobuf2_common]) from [<7f285668>] (vb2_core_streamoff+0x28/0xbc [videobuf2_common])
[ 514.199744] r10:7f590494 r9:826cc50c r8:00000001 r7:7f1b5140 r6:81005008 r5:85b34300
[ 514.199750] r4:826cc3ac r3:00000001
[ 514.199755] [<7f285640>] (vb2_core_streamoff [videobuf2_common]) from [<7f1f20f0>] (vb2_streamoff+0x24/0x64 [videobuf2_v4l2])
[ 514.199827] r5:85b34300 r4:00000001
[ 514.199832] [<7f1f20cc>] (vb2_streamoff [videobuf2_v4l2]) from [<7f1f217c>] (vb2_ioctl_streamoff+0x4c/0x50 [videobuf2_v4l2])
[ 514.199883] [<7f1f2130>] (vb2_ioctl_streamoff [videobuf2_v4l2]) from [<7f1b516c>] (v4l_streamoff+0x2c/0x30 [videodev])
[ 514.200060] r5:40045613 r4:7f1f2130
[ 514.200064] [<7f1b5140>] (v4l_streamoff [videodev]) from [<7f1ba470>] (__video_do_ioctl+0x234/0x460 [videodev])
[ 514.200324] r5:40045613 r4:826cc520
[ 514.200328] [<7f1ba23c>] (__video_do_ioctl [videodev]) from [<7f1bac30>] (video_usercopy+0x140/0x630 [videodev])
[ 514.200593] r10:00000000 r9:00000000 r8:838cbe34 r7:00000000 r6:81005008 r5:40045613
[ 514.200600] r4:40045613
[ 514.200604] [<7f1baaf0>] (video_usercopy [videodev]) from [<7f1bb140>] (video_ioctl2+0x20/0x24 [videodev])
[ 514.200869] r10:0000000f r9:71112f30 r8:85b34300 r7:00000000 r6:7110b0b0 r5:81005008
[ 514.200874] r4:7f1bb120
[ 514.200878] [<7f1bb120>] (video_ioctl2 [videodev]) from [<7f1b31f4>] (v4l2_ioctl+0x4c/0x60 [videodev])
[ 514.201137] [<7f1b31a8>] (v4l2_ioctl [videodev]) from [<80366908>] (sys_ioctl+0x12c/0xa20)
[ 514.201281] r5:81005008 r4:40045613
[ 514.201285] [<803667dc>] (sys_ioctl) from [<80100040>] (ret_fast_syscall+0x0/0x1c)
[ 514.201304] Exception stack(0x838cbfa8 to 0x838cbff0)
[ 514.201315] bfa0: 711162d8 7110b09c 0000000f 40045613 71112f30 00000000
[ 514.201326] bfc0: 711162d8 7110b09c 7110b0b0 00000036 7110b0a0 00000000 711163b8 01c00e48
[ 514.201334] bfe0: 76f0ad40 71a592dc 76e88a70 76b0ad4c
[ 514.201345] r10:00000036 r9:838ca000 r8:80100244 r7:00000036 r6:7110b0b0 r5:7110b09c
[ 514.201350] r4:711162d8
[ 514.201396] —[ end trace 6b3de61694527f09 ]—
