GStreamer test fails on Jetson Nano with Quadrascopic Camera and high 8-camera latency
Hi, I’m working on a remote-controlled sidewalk mobile robot for a Japanese manufacturer and I’m trying to cut down camera latency. We have 8 remote control cameras installed on the robot and right now the latency is around 300-400 ms, which is too much for remote driving. I need to get it down by more than half while still keeping the robot affordable.
Current setup:
  • Camera kit: B0331 (OV9782) — the 1MP*4 Quadrascopic Camera Bundle Kit
  • Two Jetson Nanos, each with 4 x 120-degree cameras installed
  • Resolution/frame rate: 800x600 @ 15fps
  • FoV: 120°
  • We’d like the 8 cameras to work via WebRTC for remote control; the sensor interface is flexible as long as all 8 can run that way.
For reference, our existing cameras are ELP units with 1/2.8" Sony IMX291 sensors, output 800x600 @ 15fps over USB 3.0.
We’ll probably need to try several prototypes. Delivery target is end of November but earlier is better. Where should we start?
Thanks for the detailed write-up. Before we chase latency, let’s make sure the capture path itself is healthy. On a Jetson Nano the usual first step is to test the camera straight through GStreamer.
Try something like:
gst-launch-1.0 v4l2src device=“/dev/video0” ! videoconvert ! ximagesink
If that misbehaves, please grab a bug report for us so we can see the kernel/media details. The tool is:
wget -O arducam-camera-bug-report-nvidia https://github.com/ketai-dhr/arducam-camera-bug-report/releases/download/tools/arducam-camera-bug-report-nvidia ; chmod +x ./arducam-camera-bug-report-nvidia ; ./arducam-camera-bug-report-nvidia
That produces an arducam-bug-report.txt you can attach here.
Do you have any update on this? We started trying to build the 4 Quadrascopic Camera with the Jetson Nano last week and got stuck.
We tried testing with GStreamer on the Jetson Nano but the test failed. This is the pipeline we used:
The console just floods with “A lot of buffers are being dropped.” and we never get a stable image.
Thanks — that tells us the capture stream isn’t stable yet, so let’s not worry about latency until we can get a clean frame out.
Can you run the bug report tool from my earlier message and attach arducam-bug-report.txt? That will show us which kernel and driver build you’re running for the OV9782 on the Nano.
Ran it — arducam-bug-report.txt is attached. Also, could you share sample code for screen output using GStreamer? We mainly want to prove we can get an image on screen first. I’ve also sent the signed NDA and our inquiry details through private message, let me know if you received them.
Got the report and your message, thanks. Here’s the key thing for this kit: the jevariety camera is reported to be incompatible with GStreamer. That’s why your v4l2src pipeline is throwing all those dropped buffers.
Please take a look at our troubleshooting guide for the OV9281/OV9782 on NVIDIA Jetson Nano:
https://www.arducam.com/docs/camera-for-jetson-nano/ov9281-ov9782-on-nvidia-jetson-nano-the-troubleshooting-guide/
Then use step 3.B. in that guide to run the test. That’s the path that actually works for this camera instead of a plain GStreamer pipeline.
So if I’m reading that right, the jevariety camera just can’t be used with GStreamer at all, and I should use step 3.B instead to verify the sensor? We’ll try that now. Once we get a clean image we’ll come back to the WebRTC/latency question for the 8-camera robot setup.
Exactly. Quick summary of where we are:
  • Root cause: the jevariety camera is not compatible with GStreamer, which is why your gst-launch v4l2src pipeline dropped buffers.
  • Solution: use step 3.B of the OV9281/OV9782 on NVIDIA Jetson Nano troubleshooting guide to run the test, instead of the plain GStreamer pipeline.
  • Guide: Redirecting...
Get a stable frame via step 3.B first, then we can look at the WebRTC path and latency for the 8-camera setup.
