http://vctec.co.kr/
UC-425 Rev.C, UC-6228 Rev.B, UC-512 Rev.C
Jetson Nano B01
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/tree/master/Nvidia_Jetson/Python/Streaming_demo
Never worked
I set up USB shield refer to [1].
I run following python code.
sudo python ArduCam_Py_Demo.py …/…/…/Config/USB3.0_UC-425_Rev.C+UC-628_Rev.B+UC-512_Rev.C/2_to_1/IMX477/Jetson/IMX477_MIPI_2Lane_RAW10_1920x1080.cfg
I get following errors.
Color mode 0
Serial: AU3S-2108-0003
Capture began, rtn_val = 0
Error capture image, rtn_val = 65316
Gtk-Message: 10:11:03.117: Failed to load module “canberra-gtk-module”
USB_CAMERA_DATA_LEN_ERROR RECEIVE_LENGTH:2072264
Error capture image, rtn_val = 65312
What do I have to check?
Thanks.
References:
Check cable connection
Give me some check point
wong
June 23, 2021, 5:14pm
2
Hi @syhuh1125
Can you provide a picture of the connection of the module?
And you don’t seem to indicate the camera module used, any purchase link, SKU number or UC number will be helpful.
UC number : UC-517 Rev.D
UC number : UC-628 Rev.B
UC number : UC-425 Rev.C
<p style=“text-align: center;”>[Fig1. Overall View ]</p>
<p style=“text-align: center;”>[ Fig2. UC-517 Rev.D and UC-425 Rev.C ]</p>
<p style=“text-align: center;”>[ Fig3. UC-628 Rev.B]</p>
<p style=“text-align: center;”>[ Fig1. Overall view ]</p>
<p style=“text-align: center;”> [ Fig 2. UC-517 Rev.D and UC-425 Rev.C ]</p>
<p style=“text-align: center;”>[ Fig3. UC-628 Rev.B ]</p>
I found the mismatch.
I have the UC-517 Rev.D.
However the configuration file is for UC-512 Rev.C.
Is this the cause of the error?
Then, can you provide me the configuration file for UC-517 Rev .D?
wong
June 24, 2021, 5:38pm
7
Hi @Syhuh1125
here is the right configuation file:
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/tree/master/Config/USB3.0_UC-425_Rev.C%2BUC-628_Rev.B/IMX477
May I know why you want to use USB instead of CSI2 interface?
(This camera can be directly connected to Jetson Nano’s CSI2 interface, imx477-how-to-install-the-driver )
Hi wong,
I tried your suggestion, but still got errors.
Color mode 0
Error capture image, rtn_val = 65318
I succeeded with CSI2 connection.
I want to extend the length of cable between camera module and Jetson Nano.
As I know, the maximum length of CSI2 cable is about 25cm ~ 30cm.
But I would like to use longer cable, so I tried USB shield.
Thanks.
wong
June 29, 2021, 2:55am
9
Can you try this configuration file? Or use USBTest GUI to test on windows, we need to confirm whether there is a problem with the hardware first.
