other
https://www.maker-shop.ch/arducam-high-quality-camera-with-6mm-cs-mount-lens-for-jetson-nano-12-3mp-1-2-3-inch-imx477
Jetson Nano B01
A bunch.
Yes. Works fine.
I would like to capture a single image in maximum resolution for further processing. I do only care about one specific frame, timing will be done via external input.
So far I found lots of gstreamer video capture examples which have been slow and your mention in another post that direct cv2 capture of the imx477 image is not possible (raw10).
In my application the capture frequency is about 2fps and I need a very low latency. The image should be completly processed when the next trigger comes in.
How would I do this? Preferably in Python3 since my other processing is handeled in python as well. Could you provide me with some example code to get a cv2 object?
Thank you
code example / link
