Robotshop -
Arducam OV9281 1MP Mono Global Shutter MIPI Camera for Raspberry Pi
Product Code: RB-Adu-109
UV-599 Rev. B
Computer module 4 with Ochin carried board dual camera configuration
https://www.seeedstudio.com/Ochin-Tiny-Carrier-Board-for-Raspberry-Pi-Compute-Module-4-p-5463.html -
I have been able to successfully run all the examples with libcamera with both cameras.
$ libcamera-vid --list-cameras
Available cameras
0 : ov9281 [1280x800] (/base/soc/i2c0mux/i2c@0/ov9281@60)
Modes: 'R8' : 640x400 [325.52 fps - (0, 0)/1280x800 crop]
1280x720 [180.51 fps - (0, 40)/1280x720 crop]
1280x800 [150.97 fps - (0, 0)/1280x800 crop]
'R10_CSI2P' : 640x400 [260.42 fps - (0, 0)/1280x800 crop]
1280x720 [144.40 fps - (0, 40)/1280x720 crop]
1280x800 [120.76 fps - (0, 0)/1280x800 crop]
1 : ov9281 [1280x800] (/base/soc/i2c0mux/i2c@1/ov9281@60)
I can stream both cameras feeds.
- Problems you were having?
V4L2 can not initialise any of the cameras failing with error 25 or 22. It seems it is not possible to access or set the cameras properties through V4L2 interface. I am not interested to rewrite already available code
Using usb_cam ros node:
Opening streaming device /dev/video0
Video4Linux: internal error occurred, hoping for device fallback
Cannot set stream parameters (25)
The command: v4l2-ctl --device=/dev/video0 -L
. Produces no output.
But v4l2-ctl --all -d /dev/video0
produces correct output:
$ v4l2-ctl --all -d /dev/video0
Driver Info:
Driver name : unicam
Card type : unicam
Bus info : platform:fe800000.csi
Driver version : 6.1.34
Capabilities : 0xa5a00001
Video Capture
Metadata Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x25200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : unicam
Serial :
Media version : 6.1.34
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000004 : 0: Sink
Link 0x02000007: from remote pad 0x1000002 of entity 'ov9281 0-0060': Data, Enabled, Immutable
Priority: 2
Video input : 0 (unicam-image: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : Interlaced
Bytes per Line : 1280
Size Image : 614400
Colorspace : SMPTE 170M
Transfer Function : Rec. 709
YCbCr/HSV Encoding: ITU-R 601
Quantization : Limited Range
Flags :
But list of available formats shows unexpected output:
v4l2-ctl --device /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
[8]: 'RGB3' (24-bit RGB 8-8-8)
[9]: 'BGR3' (24-bit BGR 8-8-8)
[10]: 'RGB4' (32-bit A/XRGB 8-8-8-8)
[11]: 'BA81' (8-bit Bayer BGBG/GRGR)
[12]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[13]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[14]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[15]: 'pBAA' (10-bit Bayer BGBG/GRGR Packed)
[16]: 'BG10' (10-bit Bayer BGBG/GRGR)
[17]: 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
[18]: 'GB10' (10-bit Bayer GBGB/RGRG)
[19]: 'pgAA' (10-bit Bayer GRGR/BGBG Packed)
[20]: 'BA10' (10-bit Bayer GRGR/BGBG)
[21]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
[22]: 'RG10' (10-bit Bayer RGRG/GBGB)
[23]: 'pBCC' (12-bit Bayer BGBG/GRGR Packed)
[24]: 'BG12' (12-bit Bayer BGBG/GRGR)
[25]: 'pGCC' (12-bit Bayer GBGB/RGRG Packed)
[26]: 'GB12' (12-bit Bayer GBGB/RGRG)
[27]: 'pgCC' (12-bit Bayer GRGR/BGBG Packed)
[28]: 'BA12' (12-bit Bayer GRGR/BGBG)
[29]: 'pRCC' (12-bit Bayer RGRG/GBGB Packed)
[30]: 'RG12' (12-bit Bayer RGRG/GBGB)
[31]: 'pBEE' (14-bit Bayer BGBG/GRGR Packed)
[32]: 'BG14' (14-bit Bayer BGBG/GRGR)
[33]: 'pGEE' (14-bit Bayer GBGB/RGRG Packed)
[34]: 'GB14' (14-bit Bayer GBGB/RGRG)
[35]: 'pgEE' (14-bit Bayer GRGR/BGBG Packed)
[36]: 'GR14' (14-bit Bayer GRGR/BGBG)
[37]: 'pREE' (14-bit Bayer RGRG/GBGB Packed)
[38]: 'RG14' (14-bit Bayer RGRG/GBGB)
[39]: 'GREY' (8-bit Greyscale)
[40]: 'Y10P' (10-bit Greyscale (MIPI Packed))
[41]: 'Y10 ' (10-bit Greyscale)
[42]: 'Y12P' (12-bit Greyscale (MIPI Packed))
[43]: 'Y12 ' (12-bit Greyscale)
[44]: 'Y14P' (14-bit Greyscale (MIPI Packed))
[45]: 'Y14 ' (14-bit Greyscale)
This appears using yavta:
yavta --capture=1 /dev/video0 -F/tmp/test-#.bin
[ 2372.142357] unicam fe800000.csi: Wrong width or height 640x360 (remote pad set to 1280x800)
[ 2372.142382] unicam fe800000.csi: Failed to start media pipeline: -22
Upgrade kernel drivers, reinstall libv4l packages, install yavta. -
Could you clarify expected V4L2 support for this camera? I am really not interested on rewriting the drivers using libcamera-app examples. I can do it, but it would mean a huge distraction.
Additional info:
Using Raspbian Bullseye
$ uname -a
Linux quadcm4 6.1.34-v8+ #1657 SMP PREEMPT Fri Jun 16 12:36:29 BST 2023 aarch64 GNU/Linux
$ dmesg
[ 8.833221] ov9281 0-0060: Detected OV009281 sensor
[ 8.833475] ov9281 0-0060: Consider updating driver ov9281 to match on endpoints
[ 8.849803] ov9281 10-0060: Detected OV009281 sensor
[ 8.849898] ov9281 10-0060: Consider updating driver ov9281 to match on endpoints
