Amazon -
New 64mp Hawkeye (arducam_64mp) -
Raspberry Pi 4 Model B Rev 1.2
4Gb RAM
Raspbian Bullseye 64-bit -
arducam_64mp_pi_camera_manual.pdf
(downloaded from Arducam website) -
libcamera-still -t 1000 -n
[0:46:22.991456064] [8340] INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4135-f8a5e271
[0:46:22.994829847] [8342] WARN CameraSensorProperties camera_sensor_properties.cpp:190 No static properties available for ‘arducam_64mp’
[0:46:22.994874550] [8342] WARN CameraSensorProperties camera_sensor_properties.cpp:192 Please consider updating the camera sensor properties database
[0:46:23.019143997] [8342] WARN RPI raspberrypi.cpp:1308 Mismatch between Unicam and CamHelper for embedded data usage!
[0:46:23.020207277] [8342] INFO RPI raspberrypi.cpp:1425 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media1 and ISP device /dev/media3
[0:46:23.020824361] [8340] INFO Camera camera.cpp:1026 configuring streams: (0) 4624x3472-YUV420
[0:46:23.021208392] [8342] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[0:46:23.137308560] [8342] ERROR V4L2 v4l2_videodevice.cpp:1906 /dev/video0[13:cap]: Failed to start streaming: Input/output error
ERROR: *** failed to start camera *** -
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 108.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2711
Revision : c03114
Serial : 1000000018594a86
Model : Raspberry Pi 4 Model B Rev 1.4
Followed all steps mentioned in Forum, PDF file and Quick start guide from arducam website.
8. What help do you need?
I need the solution to use this camera.
os-Release:
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
config.txt:
Raspberry Pi Documentation - Configuration
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d,composite
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
enable_tvout=1
dtoverlay=arducam_64mp
ls /dev/video*
/dev/video0 /dev/video12 /dev/video16 /dev/video21
/dev/video1 /dev/video13 /dev/video18 /dev/video22
/dev/video10 /dev/video14 /dev/video19 /dev/video23
/dev/video11 /dev/video15 /dev/video20 /dev/video31
dpkg -l | grep libcamera
ii libcamera-apps 0.0.11 armhf libcamera-apps
ii libcamera-dev 0.0.11 armhf libcamera
