Kickstarter campaign -
IMX519 -
RPI Zero 2 W -
https://www.arducam.com/downloads/arducam-imx519-start-guide.pdf -
Install fails at ./install_pivariety_pkgs.sh -p imx519_kernel_driver command:
install: target ‘/lib/modules/5.10.92-v8+/kernel/drivers/media/i2c/’ is not a directory: No such file or directory
depmod: ERROR: could not open directory /lib/modules/5.10.92-v8+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
dmesg.txt · GitHub -
Install fails after running sudo apt-get -y upgrade
Works if I dont upgrade -
Guessing there’s an update for the rasberry pi, which is not supported with the install script.
Noticed “Unpacking raspberrypi-kernel (1:1.20220308-2) over (1:1.20220120-1)” … when upgrading.
