I’ve been trying to correctly use an IMX219 camera with USB2.0 (fix focus) for two days. But it is impossible, I have turned the sensor to both sides and I never get a clear image. Also the image is very dark and has artifacts.
I use the camera via USB on the raspberry PI because at the same time I have a ToF connected via CSI-2. Could this be affecting you?
PD: I have the same output using the computer and another IMX219.
EDIT: I have 3 IMX219 cameras. Two of them with fixed focus (also with so many tests I think the screw thread has broken because they are no longer able to focus anymore). It can’t be that I’m damaging two cameras with this problem!
Another has a manual focus, I have adjusted it by hand. But it seems that depending on when I turn on the camera (totally random) I get an image with more or less blur.
It can’t be that I get these results, arducam is supposed to be of industrial quality and for now the only thing I’ve had are 2 broken cameras and a usb that doesn’t work.
See the following examples (pay attention on the markers)
Thanks.
