B0381 -
Raspberry Pi 5, debian bookworm newest version -
Installation for the driver here, and setup for the external trigger here (on the software section) -
upon inputting this command v4l2-ctl -d /dev/v4l-subdev0 -c trigger_mode=1,
it returned error "unknown control ‘trigger_mode’ " -
[ 44.646788] source of link ‘rp1-cfe-fe_config’:0->‘pisp-fe’:1 is not a V4L2 sub-device, driver bug!
[ 44.646807] v4l2_get_link_freq: Link frequency estimated using pixel rate: result might be inaccurate
[ 44.646809] v4l2_get_link_freq: Consider implementing support for V4L2_CID_LINK_FREQ in the transmitter driver
[ 44.646812] rp1-cfe 1f00128000.csi: Using a link rate of 800 Mbps -
anything I could do to get the external trigger working?
okay, I think I might found the solution. I ended up changing v4l-subdev0 to v4l-subdev2 and it seems to work now based on a quick test. Could you confirm that this is the intended behavior and not some fluke?
Did you connect another camera to your Pi 5?
