UCTronics, Amazon
Arducam Complete High Quality Camera Bundle for Jetson Nano, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Jetvariety Adapter Board, Metal Enclosure, Tripod and HDMI Extension Adapter
Jetson NX, Jetson Nano
Yes
I have a question about the compatibility of the newer fiber optics HDMI cables with this camera and HDMI extender. I need a 30 ft/10m lightweight HDMI cable to extend the distance from the IMX477 camera to a Jetson Nano. Will using a fiber optics such as this https://www.amazon.com/Cable-Matters-Active-Signal-Booster/dp/B07WNXLFM3/ref=sr_1_8?dchild=1&keywords=active+fiber+hdmi+cable+10m&qid=1615845616&refinements=p_36%3A-6500&rnid=386442011&sr=8-8 work or is copper required for power? If not, can 5v power be injected into a copper HDMI cable to power the camera?
