UCTRONICS
AR1820HS
Nvidia Xavier NX
https://github.com/ArduCAM/MIPI_Camera/blob/master/Jetson/Jetvariety/example/arducam_displayer.py
Works not bad but I need settings
Hi Everyone,
I tried the last version of the driver for the Xavier NX and my AR1820HS, and it’s now working, congratulations Arducam !
But of course I still have a problem… I cannot set properly the exposure, so the picture it very dark. How can I do ? I tested this script :
Any idea of how I can fix it ?
I also tried these lines :
cap.set(cv2.CAP_PROP_AUTO_EXPOSURE, 0.25)
cap.set(cv2.CAP_PROP_EXPOSURE, -2)
=> no effect on the result (even inserted after the line “ret, frame = cap.read()”)…
Thanks
