Arducam Pivariety 8MP Synchronized Stereo 360° Camera Kit for Raspberr– The Pi Hut -
IMX219 8MPx2 -
Raspberry Pi 4, Buster -
Set up the camera on a fresh install of Buster on a raspberry pi 4 and accessing the camera through python and opencv with the use of v4l2 loopback and gstreamer as explained here:
How to access and program the Pivariety Camera using Command Line, Python, OpenCV, and GStreamer -
Unable to manually control the exposure of the cameras through opencv. Manual exposure is required due to the use of a filter on one camera but the exposure is being set automatically from the brighter image with no filter. -
How can the exposure of the cameras be controlled for the stereo camera hat when a live stream is required?
Unfortunately, if you are using v4l2loopback, you can only set parameters when libcamera starts, not dynamically modify parameters through opencv.
Okay thanks. I am currently starting the v4l2 loop back with the following commands, is there a way to set the exposure within this?
sudo modprobe v4l2loopback video_nr=3
export GST_PLUGIN_PATH=$(pwd)/build/src/gstreamer
gst-launch-1.0 libcamerasrc ! ‘video/x-raw,width=1920,height=540’ ! videoconvert ! tee ! v4l2sink device=/dev/video3
Looks like we’ve run into another trouble,
The gstreamer plugin does not support setting exposure manually.
