I would not connect a 9V battery to an ESP32 board. I believe they only run on 5V or USB. You will probably fry your board if you do this. I guess you could create a voltage divider circuit to provide 5V from a 9V battery.
I have the Arducam IoTai which, I believe is the same as the Arducam ESP32 PSRAM. I had to purchase a good USB Data Cable to make it work properly.
problem has not been solved… now i want to record video and stored it into the SD card without wifi connection(offline). If any body have an idea then share it please… any sketch that i can use…?? @Valdhor
i am trying to record with this sketch that is available in examples of Arducam
SPI_Camera Arducam_ESP32_Video2SD
Code has been successfully uploaded on UNO PSRAM board and camera has been initialized but giving error on writing on Sd card… Please can anyone guide me how can i solved it…
