UCTTRONICS
MT9F001 (UC397 RevA) Camera and UC-425 Rev C USB Shield
Raspberry Pi 4B
ArduCam GitHub / SDK documentation
Yes
I can run the streaming demo just fine once. However, if I quit the script by entering “q” and try to run the script again, I get errors. See below for shell output:
First run:
~ $ sudo python Streaming_demo/ArduCam_Py_Demo.py Streaming_demo/MT9F001_RAW_8b_4384x3288_5fps.cfg
(‘color mode’, 0)
setFramerate not a function
Serial: AU3S-2027-0001
('Capture began, rtn_val = ', 0L)
fps: 3 /s
q
device close success!
Second run:
(‘color mode’, 0)
('Error capture image, rtn_val = ', 65318L)
q
No images are saved in the second run and the script only works again after I reboot
the system. Any advice?
Clearing cache, reading trhough script code
Offering solution
