Background:
New out of the box ToF raspberry pi camera being installed on a fresh Bullseye (version 11) 64 bit Raspberry OS, installed on a 8GB PI-4.
When installing the Time-Of-Oflight Raspberry Pi camera according to the installation guide (both on the web page and pdf) in in phase 4 it generates an error:
v4l2_device_open_v4l2_subdev WARNING Link '…/…/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/video4linux/video0' does not contain '/v4l-subdev'
VIDIOC_S_CTRL: Bad file descriptor
Segmentation fault
ending the compilation (fase 4 ) in an error state. I have raised a ticket with Arducam support team. But maybe someone has encountered the same problem or knows the solution to the problem?
I will post the solution in due time,
Thanks, Frank.
Update: I checked the maual installation on Github, I think the installation steps are not doing what they should do. The config.txt should be changed during installation, this is not properly executed.
I retried an installing on a freshly installed bullseye, I changed the config.txt according to the manual installation, reboot, still the same error occurs: does not contain ‘/v4l-subdev’.
Maybe any suggestions?
