Error installing Arducam Jetvariety camera driver on NVIDIA Orin NX: No DTB found
Hi all, I’m trying to get an AR0234 set up to acquire video on my NVIDIA Orin NX Developer Kit. It’s an Arducam Jetvariety Camera and I’m following the quick start guide, but when I run ./install_full.sh -m arducam the install errors out partway through.
Setup details:
  • NVIDIA Orin NX Developer Kit
  • Arducam Jetvariety Camera
  • Kernel package: arducam-nvidia-l4t-kernel-t234-nx-5.10.104-tegra-35.3.1-20230725012901_arm64.deb
I followed the instructions here:
Anyone hit this before?
Welcome! Could you paste the full terminal output from running ./install_full.sh -m arducam? The tail of the log will show whether it’s failing during the kernel deb install or later in the dtoverlay step.
Sure, here’s the full output:
Selecting previously unselected package arducam-nvidia-l4t-kernel.
(Reading database … 157997 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t234-nx-5.10.104-tegra-35.3.1-20230725012901_arm64.deb …
Unpacking arducam-nvidia-l4t-kernel (5.10.104-tegra-35.3.1-20230725012901) …
Setting up arducam-nvidia-l4t-kernel (5.10.104-tegra-35.3.1-20230725012901) …
File “/opt/arducam/jetson-io/config-by-hardware.py”, line 125, in
main()
File “/opt/arducam/jetson-io/config-by-hardware.py”, line 94, in main
jetson = board.Board()
File “/opt/arducam/jetson-io/Jetson/board.py”, line 230, in init
self.dtb = _board_get_dtb(self.compat, self.model, dtbdir)
File “/opt/arducam/jetson-io/Jetson/board.py”, line 114, in _board_get_dtb
raise RuntimeError(“No DTB found for %s!” % model)
RuntimeError: No DTB found for NVIDIA Orin NX Developer Kit!
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
Unknown error, please send the error message to [email protected]
The key line is RuntimeError: No DTB found for NVIDIA Orin NX Developer Kit!. That comes from the package’s post-install script. When the kernel deb is set up, it runs /opt/arducam/jetson-io/config-by-hardware.py, which calls board.Board() and then _board_get_dtb(). That function looks through the Arducam jetson-io DTB directory for a device tree blob matching the board model it detected, and it doesn’t find one, so it raises the RuntimeError. dpkg then sees the post-install script fail and reports exit status 255.
In my experience this usually shows up when the board isn’t one of the supported models — a third-party carrier board can make the model detection report something that has no matching DTB in the package. Could you confirm which carrier board you’re using? I’ve also sent you a private message with instructions on how to share front and back photos of the Orin NX so we can verify whether it’s a third-party carrier.
Thanks. I followed both the JetVariety Camera quick start guide and the Orin Nano/NX quick start for the Arducam JetVariety camera, and it still fails at the same spot — the arducam-nvidia-l4t-kernel post-installation script. I don’t have another board handy to test against. Let me check the carrier board details and the photo instructions you sent.
Right, the failure isn’t about missing a docs step — the install gets as far as unpacking the kernel deb, but the post-install script can’t find a DTB for the board model it detected. That No DTB found error means _board_get_dtb didn’t locate a matching device tree blob for ‘NVIDIA Orin NX Developer Kit’ in the package’s DTB directory. If this were a supported carrier board with a DTB shipped in the package, that lookup would succeed and the script would continue on to install the dtoverlays. Since it can’t, the post-install script exits 255 and dpkg flags the package as failed.
Please check the private message I sent — sharing front and back photos of the Orin NX will let us confirm whether it’s a third-party carrier board. That’s the most likely root cause here.
Got it, I’ll take a look at the photo instructions. So to make sure I understand: config-by-hardware.py can’t find a matching DTB for my board model, which is why the dtoverlay install aborts and dpkg turns the package install into an error state?
Exactly. To summarize where we are:
  • ./install_full.sh -m arducam gets as far as unpacking arducam-nvidia-l4t-kernel-t234-nx-5.10.104-tegra-35.3.1-20230725012901_arm64.deb.
  • During Setting up arducam-nvidia-l4t-kernel, the post-install script /opt/arducam/jetson-io/config-by-hardware.py runs and hits RuntimeError: No DTB found for NVIDIA Orin NX Developer Kit! at _board_get_dtb in Jetson/board.py.
  • Because no matching device tree blob is found, dtoverlay installation aborts, the post-install script returns 255, and dpkg flags the package as failed.
The current working conclusion is that the detected board model isn’t covered by the DTB directory in this package — commonly seen when a third-party carrier board is being used. Once we verify the carrier board (check the photo instructions I sent by private message), we can figure out the next step. Until then the install will keep failing at the same spot.
