Hi everyone, I’m trying to get an Arducam 12MP IMX477 mini (the Raspberry Pi version) working on a Jetson Nano board running Ubuntu. I followed the quick start guide here: Quick-Start-Guide - Arducam Wiki
Everything looks fine until I run ./install_full.sh -m imx477. The installer downloads the kernel package, but then it fails. Has anyone run into this before?
Can you paste the full output from the installer? The part right before and after where it fails would be most helpful. Also, what carrier board is your Nano module plugged into?
Then it reads the database and unpacks the package:
(Reading database ... 354967 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t210-4.9.253-tegra-32.6.1-20220124024834_arm64_imx477.deb ...
Unpacking arducam-nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20220124024834) over (4.9.253-tegra-32.6.1-20220124024834) ...
Setting up arducam-nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20220124024834) ...
The package itself unpacks fine, so the failure looks like it’s happening in the package’s post-installation script. Can you run it again and capture the traceback that shows up right before the dpkg error?
File "/opt/arducam/jetson-io/config-by-hardware.py", line 125, in <module>
main()
File "/opt/arducam/jetson-io/config-by-hardware.py", line 99, in main
raise RuntimeError("Platform not supported, no headers found!")
RuntimeError: Platform not supported, no headers found!
Jetson Nano CSI Connector not found.
main()
2
And the installer also prints:
OK, that confirms where it’s dying. The important lines are:
and
dpkg: error processing package arducam-nvidia-l4t-kernel (--install):
This usually means the installer’s config-by-hardware.py couldn’t detect the platform and CSI connector. In most cases we see this when the module is on a non-official/third-party carrier board rather than the official one. Can you tell me exactly which carrier board you’re using, and post pictures of the front and back of the board?
I’m connecting the Arducam 12MP IMX477 mini to a Jetson Nano running Ubuntu. Let me double-check the carrier board and I’ll get some photos of the front and back.
To summarize where things stand: the kernel package downloads and unpacks successfully, but the post-installation script fails during dtoverlay installation. The errors Platform not supported, no headers found! and Jetson Nano CSI Connector not found. indicate that config-by-hardware.py couldn’t identify the expected platform/CSI connector on your board. That failure makes the post-install script return exit status 255, which is what dpkg reports.
This pattern strongly suggests a hardware/platform detection problem, most likely a non-official carrier board. Once you can confirm which carrier board you have and post front/back photos, we can verify whether that’s the cause and go from there.
