Hi Arducam support team,
I am developing multiple camera based monitoring system for the moving vehicle, where I am using 120 fps supported B0348 camera with raspberry pi 4. As per given manual, I have installed all the driver, library, kernel without any error. But while testing it is giving error and not working with gstreamer.
System detail
cam@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
cam@raspberrypi:~ $ cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
cam@raspberrypi:~ $ cat /proc/meminfo
MemTotal: 3748352 kB
MemFree: 3087628 kB
MemAvailable: 3404340 kB
Buffers: 23404 kB
Cached: 426144 kB
SwapCached: 0 kB
Active: 89120 kB
Inactive: 461176 kB
Active(anon): 1104 kB
Inactive(anon): 127096 kB
Active(file): 88016 kB
Inactive(file): 334080 kB
Unevictable: 20400 kB
Mlocked: 16 kB
HighTotal: 3080192 kB
HighFree: 2512100 kB
LowTotal: 668160 kB
LowFree: 575528 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 121220 kB
Mapped: 139348 kB
Shmem: 27452 kB
KReclaimable: 18988 kB
Slab: 39996 kB
SReclaimable: 18988 kB
SUnreclaim: 21008 kB
KernelStack: 2008 kB
PageTables: 5156 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1976572 kB
Committed_AS: 1048780 kB
VmallocTotal: 245760 kB
VmallocUsed: 6076 kB
VmallocChunk: 0 kB
Percpu: 448 kB
CmaTotal: 327680 kB
CmaFree: 311772 kB
cam@raspberrypi:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=arducam
gpu_mem=256
cam@raspberrypi:~ $ dmesg | grep "arducam"
[ 10.142226] arducam-pivariety 10-000c: firmware version: 0x10002
[ 10.658911] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
cam@raspberrypi:~ $
[0:10:22.156297689] [1502] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam-pivariety'
[0:10:22.156377130] [1502] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:10:22.195667674] [1502] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[0:10:22.547795554] [1502] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
Error while running Gstreamer Command
cam@raspberrypi:~/arducam $ gst-launch-1.0 libcamerasrc ! 'video/xraw,width=1920,height=1080' ! videoconvert ! autovideosink
WARNING: erroneous pipeline: could not link libcamerasrc0 to videoconvert0, neither element can handle caps video/xraw, width=(int)1920, height=(int)1080
Please guide me to fix library/driver issue.
