The camera works fine with v4l2src plugin but I want to use uvch264src in order to be able to define the bitrate. However, when I use uvch264src I get the following error:
ERROR: from element /GstPipeline:pipeline0/GstUvcH264Src:src: Device is not a valid UVC H264 camera
This is the result when I use the following pipeline:
We tested it, and it does appear the same error as you.But with this command I can successfully display the camera in h264 format,It is recommended that you modify the function you want on this basis.
Thanks. Yes, I know I can v4l2src but the problem is that I want to manually control the bitrate. I can’t do that with v4l2src and uvch264srcwas an option.
I conducted further tests, and it seems that there are not many compatible devices for the uvch264src plug-in. I used devices from Logitech and Songix for testing, and the results were not supported.
I took a look at his source code and used the XU control to judge the device
XU is a unit provided for specific suppliers to add specifications, and it can be fully customized. I haven’t seen how they customize this rule.
We have software in windows that can control the code rate, if you can accept it, I can also share it with you
Hello @Edward
Facing the same issue with another H264 camera of yours. It seems that indeed the devices control H264 parameters via a non-standard XU. If you are able to share any software (incl. Windows) or documentation for that it would be greatly appreciated. We might be able to cook up a driver for other people to use.
@Edward
Thanks. We ran it and it doesn’t seem to be offering bitrate selection either. Maybe we haven’t looked enough, can you please make a screenshot in your spare time?
Alternatively, is there a chip manufacturer that’s used in the module we could reach out to for the documentation? Can sign NDAs etc if needed be.
Hello @Edward
Awesome, it works for us. It is indeed a nonstandard XU, but the application does change the params (we verified with ultra low and ultra high bitrates), so we’ll try to reverse it for our needs.
I have a follow up question, our camera is an IMX291 StarVis one. I checked the image at night and it’s not particularly impressive. At the same time I don’t seem to find any shutter or ISO settings either. Perhaps this is also done by a similar software? Can you guide us please on this as well?
The imx291 is a starry night vision camera that supports HCG (High Conversion Gain) mode.
The firmware of this camera prioritizes frame rate, and there are certain brightness restrictions.
The corresponding control also requires firmware cooperation. If you find these basic functions unsatisfactory, please fill out the form to submit your requirements.
