UCTRONICS
https://www.arducam.com/product/arducam-ov9281-mipi-1mp-monochrome-global-shutter-ir-camera-module-for-jetson-nano/
Jetson Nano Development Kit
I am trying to publish camera images over a ROS topic on Jetson Nano (with OV9281 global shutter camera). The total frame read and publish/conversion times are about 15ms. The frame format is 640x400@20fps in gray mode. The software publishes over the camera topic at about 20Hz without any problems.
However, there is a time delay between the captured image and the real movements when I check the frames via rqt_image_view.
How can I reduce the delay? What can be the problem?
Note: Opencv + v4l2 api is used to capture the images.
Best regards,
Mert Turanli
How can I reduce the delay between the motion and captured image?
