CSI to HDMI with B0399 64mp cam [rasp pi 5]
Hi I just connected a b0399 camera to my raspberry pi5, it works fine. Then I wanted to connect it using the adapter csi to hdmi arducam, but I help error messages and an image whose colors and quality are problematic ^^. Thanks to vou if you have an idea where this can come from!
[1:33:48.307623779] [2960] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
This error does not matter. I wanna know how long is the HDMI cable you used.
Hi
I tried first with a ten meters long cable, then with a five meters, neither of them permits a good images ; bit today i tried with a one meter long cable and it work fine…
I need to place the raspberry until seven and eight meters, i guess it will be better if i use https://www.arducam.com/product/15-meter-cable-extension-kit-2/
Yess. I have tried a 10m LAN cable with B0399 and it worked very well.
Bingo! I thought you were using a long HDMI cable. The longer the HDMI cable is, the worse the performance it is.
