Kubii
EK030 with serial number : 3272496313125
Arducam108Mp with USB3 CameraSHield and official USB3 cable.
Linux Ubuntu 22.04 + Python 3.9 + ArducamSDK v1.0.2
Windows 10 + Python 3.9 + ArducamSDK v1.0.2
Tested with Arducam_Demo and GUI on windows
github demo : GitHub - ArduCAM/ArduCAM_USB_Camera_Shield_Python_Demo
Install udev rules on Ubuntu 22.04 and Drivers on windows 11 from arducam github repository
CLone Arducam and Arducam Examples github repo.
Run the Demo
python3 ArduCam_Demo.py -v --preview-width 1280 -f ArduCAM_108MP_MIPI_2Lane_RAW8_4000x3000_12fps.cfg
config file from : [ArduCAM_USB_Camera_Shield/Config/USB3.0_UC-593 Rev.C/MIPI/ArduCAM_108MP at master · ArduCAM/ArduCAM_USB_Camera_Shield · GitHub]
- Problems you were having?
Cannot get image from camera when config file is set with FORMAT other than RAW (0, 0) or MONO (4)
RAW image (either RG, GR, GB, BG) only give GRAY image (acquired data length : 12000000 with SIZE config : 4000x3000)
On Ubuntu 22.04 :
[81074.651226] usb 4-1: new SuperSpeed USB device number 5 using xhci_hcd
[81074.671852] usb 4-1: LPM exit latency is zeroed, disabling LPM.
[81074.672461] usb 4-1: New USB device found, idVendor=04b4, idProduct=03f2, bcdDevice= 0.00
[81074.672467] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[81074.672470] usb 4-1: Product: FX3
[81074.672472] usb 4-1: Manufacturer: Arducam
Trying Arducam_Demo.py (python3 ArduCam_Demo.py -v --preview-width 1280 -f ) while changing FORMAT parameter from original config file ( **ArduCAM_108MP_MIPI_2Lane_RAW8_4000x3000_12fps.cfg)
- What help do you need?
I need to use Arducam 108Mp to get 4000x3000 and full res RGB or color RAW image using Python.
Hi Arducam,
For an industrial project i’m working on, I need color image from my 108Mp + Camera SHield USB3.
Based on arducam github demo repository and from example GUI on windows I an only able to get monochrome RAW image (with color deviation green, purple, etc.) or grayscale image.
I found other thread linked to this problem on the forum or elsewhere but no solution was provided.
Except this “color problem”, camera is working great either in 4000x3000 and full-resolution with Python on WIndows 11 and Ubuntu 22.04.
Really appreciate your help,
Regards,
Julien Baumeyer
