Capturing pure NIR images with Arducam IR-CUT camera on Jetson Orin Nano
Hey everyone, I have an Arducam High Quality IR-CUT Camera — the 12.3MP IMX477 HQ Camera Module with the 6mm CS lens — connected to an NVIDIA Jetson Orin Nano Developer Kit. I’m trying to capture pure NIR (near infrared) images with this setup. The camera has an IR-CUT filter built in and I’m not sure if there’s any way to disable it or customize the module so that it only captures NIR. Has anyone done this before? Any pointers would be appreciated.
Welcome to the forum! So the IR-CUT filter on that camera module is actually controlled by a photoresistor that’s sitting right on the camera board itself. By default, under normal lighting conditions, the photoresistor detects ambient light and keeps the IR-CUT filter engaged in the optical path — that’s what gives you standard visible-light images by blocking IR. The good news is you don’t need any software customization or driver changes to switch it. The photoresistor handles the switching automatically based on how much light hits it.
Here’s something you can try right now: use your finger to cover the photoresistor on the camera board. When you block light from reaching it, the photoresistor triggers the IR-CUT filter to disengage — basically swinging it out of the optical path. Once the filter is out of the way, NIR light can reach the IMX477 sensor directly, and you’ll be capturing NIR images. Give that a shot and let me know what you see.
Oh wow, that’s way simpler than I expected. I was worried I’d need to physically remove the filter or flash custom firmware. Just to make sure I understand — so the photoresistor is basically acting like a light sensor that decides whether the IR-CUT filter should be in front of the sensor or not? Cover it → thinks it’s dark → removes the IR filter → NIR passes through? I’ll give it a try and report back.
Exactly right. The photoresistor’s resistance changes based on ambient light levels, and the circuit on the camera board uses that to drive the IR-CUT switching mechanism. When it’s dark (or when you cover it with your finger), the resistance goes high, the circuit interprets that as low-light conditions, and it retracts the IR-CUT filter. That lets the full spectrum — including NIR — hit the sensor. It’s the same mechanism the camera uses for night-mode IR switching, you’re just manually triggering it. Let us know how the test goes!
