Is there a way programmatically, using the mipi camera driver, to capture images in Mode 1 (8112 x 3040) vs. the default of Mode 0 (4056 x 3040).
I know this is possible using the command line using ./arducamstill -t 5000 -m 1 -o image.jpg, but I would like to modify something like the provided capture.py file (in MIPI_Camera/RPI/python) to trigger this capture at the higher resolution
UCTRONICS
B0265R Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi, Two 12.3MP IMX477 Camera Modules with CS Lens and Camarray Stereo Camera HAT
Raspberry Pi 4B 4gb
online
yes
outlined above
I changed gpu_mem to 400, but that (alone) did not fix the issue and I continued to get the same error.
I found I also had to increase the limit of the contiguous memory allocator. In /boot/cmdline.txt I added the option cma=400M. Then rebooted and it worked.
