https://www.robotshop.com/en/arducam-mini-camera-module-w--2mp-plus-ov2640-arduino.html
ArduCam 2MP OV2640
TTGO LoRa32 Oled v1
https://github.com/ArduCAM/ArduCAM_ESP32S_UNO/tree/master/libraries/ArduCAM
No
Hi ,
now i really get lost. I need your help.
I connected the ArduCam correctly an get positive return messages for SPI & I2C checks.
I even tried with a new bought ArduCam, but no luck, I even did not get the sample code working.
The hardware does not take a picture, i do not understand why:
#define ESP32 1;
#include <Arduino.h>
#include “FS.h”
#include “SPIFFS.h”
#include <Wire.h>
#include <SPI.h>
#include <ArduCAM.h>
#include “memorysaver.h”
const int CS = 18;
//Version 2,set GPIO0 as the slave select :
const int SD_CS = 0;
ArduCAM myCAM(OV2640, CS);
uint32_t length = 0;
void capture()
//Flush the FIFO
myCAM.flush_fifo();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Start capture
//Start capture
myCAM.start_capture();
Serial.println(F(“Start Capture”));
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK))
Serial.println(F(“Capture Done.”));
void setup()
uint8_t vid, pid;
uint8_t temp;
Wire.begin(4, 15);
Serial.begin(115200);
Serial.println(“ArduCAM Start!”);
//set the CS as an output:
pinMode(CS, OUTPUT);
//initialize SPI:
SPI.begin();
SPI.setFrequency(8000000); //4MHZ
SPI.setDataMode(0);
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
delay(100);
while (1)
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55)
Serial.println(F(“SPI interface Error!”));
delay(1000);
continue;
else
Serial.println(F(“SPI interface OK!”));
break;
while (1)
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.wrSensorReg8_8(0x12, 0x80);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26) && ((pid != 0x41) || (pid != 0x42)))
Serial.println(F(“Can’t find OV2640 module!”));
delay(1000);
continue;
else
Serial.println(F(“OV2640 detected.”));
break;
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_320x240);
delay(1000);
void loop()
// put your main code here, to run repeatedly:
delay(5000);
capture();
It would be great if you can point me to the issue. Thank you very much.
Check if the ArduCam init is correct and get the ArduCam working on my site.
