uctronics -
ov9281-B0405 -
RPI 4 - 2GB -
Quick Start - Arducam Wiki -
When I run libcamera-hello it shows the preview window but I get the following warnings like “Could not set SATURATION”. Also I cannot use the camera with OpenCV.
pi@raspberrypi:~/temp $ libcamera-hello
Made X/EGL preview window
[0:58:02.938469883] [1398] INFO Camera camera_manager.cpp:299 libcamera v0.0.4+22-923f5d70
[0:58:02.961832288] [1413] WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for ‘ov9281’
[0:58:02.961932361] [1413] WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:58:02.979159103] [1413] INFO RPI raspberrypi.cpp:1476 Registered camera /base/soc/i2c0mux/i2c@1/ov9281@60 to Unicam device /dev/media4 and ISP device /dev/media1
[0:58:02.980077128] [1398] INFO Camera camera.cpp:1028 configuring streams: (0) 640x400-YUV420
[0:58:02.980917821] [1413] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/i2c@1/ov9281@60 - Selected sensor format: 640x400-Y10_1X10 - Selected unicam format: 640x400-Y10P
[0:58:02.986635767] [1416] WARN IPARPI raspberrypi.cpp:1042 Could not set SATURATION - no ccm algorithm
[0:58:02.986735376] [1416] WARN IPARPI raspberrypi.cpp:1057 Could not set SHARPNESS - no sharpen algorithm
[0:58:02.986821116] [1416] WARN IPARPI raspberrypi.cpp:974 Could not set AWB_MODE - no AWB algorithm
terminate called after throwing an instance of ‘std::runtime_error’
what(): failed to import fd 19
Aborted
un 8 08:25:41 raspberrypi kernel: [ 1.457337] brd: module loaded
Jun 8 08:25:41 raspberrypi kernel: [ 1.466369] loop: module loaded
Jun 8 08:25:41 raspberrypi kernel: [ 1.467262] Loading iSCSI transport class v2.0-870.
Jun 8 08:25:41 raspberrypi kernel: [ 1.472967] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
Jun 8 08:25:41 raspberrypi kernel: [ 1.533785] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
Jun 8 08:25:41 raspberrypi kernel: [ 1.535021] usbcore: registered new interface driver r8152
Jun 8 08:25:41 raspberrypi kernel: [ 1.535115] usbcore: registered new interface driver lan78xx
Jun 8 08:25:41 raspberrypi kernel: [ 1.535175] usbcore: registered new interface driver smsc95xx
Jun 8 08:25:41 raspberrypi kernel: [ 1.584097] pci 0000:00:00.0: enabling device (0000 → 0002)
Jun 8 08:25:41 raspberrypi kernel: [ 1.584284] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jun 8 08:25:41 raspberrypi kernel: [ 1.584342] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
Jun 8 08:25:41 raspberrypi kernel: [ 1.585136] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
Jun 8 08:25:41 raspberrypi kernel: [ 1.586300] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jun 8 08:25:41 raspberrypi kernel: [ 1.586324] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
Jun 8 08:25:41 raspberrypi kernel: [ 1.586349] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
Jun 8 08:25:41 raspberrypi kernel: [ 1.586759] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
Jun 8 08:25:41 raspberrypi kernel: [ 1.586779] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 8 08:25:41 raspberrypi kernel: [ 1.586795] usb usb1: Product: xHCI Host Controller
Jun 8 08:25:41 raspberrypi kernel: [ 1.586809] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
Jun 8 08:25:41 raspberrypi kernel: [ 1.586823] usb usb1: SerialNumber: 0000:01:00.0
Jun 8 08:25:41 raspberrypi kernel: [ 1.587610] hub 1-0:1.0: USB hub found
Jun 8 08:25:41 raspberrypi kernel: [ 1.587683] hub 1-0:1.0: 1 port detected
Jun 8 08:25:41 raspberrypi kernel: [ 1.588656] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
Jun 8 08:25:41 raspberrypi kernel: [ 1.588677] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 8 08:25:41 raspberrypi kernel: [ 1.588692] usb usb2: Product: xHCI Host Controller
Jun 8 08:25:41 raspberrypi kernel: [ 1.588705] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
Jun 8 08:25:41 raspberrypi kernel: [ 1.588719] usb usb2: SerialNumber: 0000:01:00.0
Jun 8 08:25:41 raspberrypi kernel: [ 1.589398] hub 2-0:1.0: USB hub found
Jun 8 08:25:41 raspberrypi kernel: [ 1.589493] hub 2-0:1.0: 4 ports detected
Jun 8 08:25:41 raspberrypi kernel: [ 1.591445] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 8 08:25:41 raspberrypi kernel: [ 1.592461] usbcore: registered new interface driver uas
Jun 8 08:25:41 raspberrypi kernel: [ 1.592566] usbcore: registered new interface driver usb-storage
Jun 8 08:25:41 raspberrypi kernel: [ 1.592813] mousedev: PS/2 mouse device common for all mice
Jun 8 08:25:41 raspberrypi kernel: [ 1.599808] sdhci: Secure Digital Host Controller Interface driver
Jun 8 08:25:41 raspberrypi kernel: [ 1.599830] sdhci: Copyright(c) Pierre Ossman
Jun 8 08:25:41 raspberrypi kernel: [ 1.600552] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 8 08:25:41 raspberrypi kernel: [ 1.604353] ledtrig-cpu: registered to indicate activity on CPUs
Jun 8 08:25:41 raspberrypi kernel: [ 1.604732] hid: raw HID events driver (C) Jiri Kosina
Jun 8 08:25:41 raspberrypi kernel: [ 1.604971] usbcore: registered new interface driver usbhid
Jun 8 08:25:41 raspberrypi kernel: [ 1.604986] usbhid: USB HID core driver
Jun 8 08:25:41 raspberrypi kernel: [ 1.614565] NET: Registered PF_PACKET protocol family
Jun 8 08:25:41 raspberrypi kernel: [ 1.614712] Key type dns_resolver registered
Jun 8 08:25:41 raspberrypi kernel: [ 1.616172] registered taskstats version 1
Jun 8 08:25:41 raspberrypi kernel: [ 1.616263] Loading compiled-in X.509 certificates
Jun 8 08:25:41 raspberrypi kernel: [ 1.617190] Key type .fscrypt registered
Jun 8 08:25:41 raspberrypi kernel: [ 1.617204] Key type fscrypt-provisioning registered
Jun 8 08:25:41 raspberrypi kernel: [ 1.634137] uart-pl011 fe201000.serial: there is not valid maps for state default
Jun 8 08:25:41 raspberrypi kernel: [ 1.634916] uart-pl011 fe201000.serial: cts_event_workaround enabled
Jun 8 08:25:41 raspberrypi kernel: [ 1.635085] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
Jun 8 08:25:41 raspberrypi kernel: [ 1.644602] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Jun 8 08:25:41 raspberrypi kernel: [ 1.645070] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Jun 8 08:25:41 raspberrypi kernel: [ 1.646538] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
Jun 8 08:25:41 raspberrypi kernel: [ 1.646560] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
Jun 8 08:25:41 raspberrypi kernel: [ 1.674702] of_cfs_init
Jun 8 08:25:41 raspberrypi kernel: [ 1.674855] of_cfs_init: OK
Jun 8 08:25:41 raspberrypi kernel: [ 1.710616] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
Jun 8 08:25:41 raspberrypi kernel: [ 1.710992] Waiting for root device PARTUUID=8c75c429-02…
Jun 8 08:25:41 raspberrypi kernel: [ 1.757942] mmc1: new high speed SDIO card at address 0001
Jun 8 08:25:41 raspberrypi kernel: [ 1.813887] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
Jun 8 08:25:41 raspberrypi kernel: [ 1.815000] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
Jun 8 08:25:41 raspberrypi kernel: [ 1.818408] mmcblk0: p1 p2
Jun 8 08:25:41 raspberrypi kernel: [ 1.819017] mmcblk0: mmc0:aaaa SD32G 29.7 GiB (quirks 0x00004000)
Jun 8 08:25:41 raspberrypi kernel: [ 1.832549] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
Jun 8 08:25:41 raspberrypi kernel: [ 1.832653] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jun 8 08:25:41 raspberrypi kernel: [ 1.833473] devtmpfs: mounted
Jun 8 08:25:41 raspberrypi kernel: [ 1.841763] usb 1-1: new high-speed USB device number 2 using xhci_hcd
Jun 8 08:25:41 raspberrypi kernel: [ 1.843252] Freeing unused kernel memory: 4160K
Jun 8 08:25:41 raspberrypi kernel: [ 1.843439] Run /sbin/init as init process
Jun 8 08:25:41 raspberrypi kernel: [ 1.992268] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
Jun 8 08:25:41 raspberrypi kernel: [ 1.992308] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Jun 8 08:25:41 raspberrypi kernel: [ 1.992325] usb 1-1: Product: USB2.0 Hub
Jun 8 08:25:41 raspberrypi kernel: [ 1.994161] hub 1-1:1.0: USB hub found
Jun 8 08:25:41 raspberrypi kernel: [ 1.994553] hub 1-1:1.0: 4 ports detected
Jun 8 08:25:41 raspberrypi kernel: [ 2.289687] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
Jun 8 08:25:41 raspberrypi kernel: [ 2.359730] NET: Registered PF_INET6 protocol family
Jun 8 08:25:41 raspberrypi kernel: [ 2.361858] Segment Routing with IPv6
Jun 8 08:25:41 raspberrypi kernel: [ 2.361903] In-situ OAM (IOAM) with IPv6
Jun 8 08:25:41 raspberrypi kernel: [ 2.396601] usb 1-1.1: New USB device found, idVendor=0461, idProduct=4d15, bcdDevice= 2.00
Jun 8 08:25:41 raspberrypi kernel: [ 2.396643] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jun 8 08:25:41 raspberrypi kernel: [ 2.396660] usb 1-1.1: Product: USB Optical Mouse
Jun 8 08:25:41 raspberrypi kernel: [ 2.406057] input: USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:0461:4D15.0001/input/input0
Jun 8 08:25:41 raspberrypi kernel: [ 2.406581] hid-generic 0003:0461:4D15.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:01:00.0-1.1/input0
Jun 8 08:25:41 raspberrypi kernel: [ 2.485665] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
Jun 8 08:25:41 raspberrypi kernel: [ 2.600940] usb 1-1.2: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.01
Jun 8 08:25:41 raspberrypi kernel: [ 2.600982] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 8 08:25:41 raspberrypi kernel: [ 2.600999] usb 1-1.2: Product: Dell USB Keyboard
Jun 8 08:25:41 raspberrypi kernel: [ 2.601013] usb 1-1.2: Manufacturer: Dell
Jun 8 08:25:41 raspberrypi kernel: [ 2.613697] input: Dell Dell USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:2003.0002/input/input1
Jun 8 08:25:41 raspberrypi kernel: [ 2.674680] hid-generic 0003:413C:2003.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:01:00.0-1.2/input0
Jun 8 08:25:41 raspberrypi kernel: [ 3.634540] fuse: init (API version 7.37)
Jun 8 08:25:41 raspberrypi kernel: [ 3.689431] i2c_dev: i2c /dev entries driver
Jun 8 08:25:41 raspberrypi kernel: [ 3.958771] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
Jun 8 08:25:41 raspberrypi kernel: [ 5.353332] mc: Linux media interface: v0.10
Jun 8 08:25:41 raspberrypi kernel: [ 5.475043] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 5.477128] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Jun 8 08:25:41 raspberrypi kernel: [ 5.477166] [vc_sm_connected_init]: start
Jun 8 08:25:41 raspberrypi kernel: [ 5.530210] [vc_sm_connected_init]: installed successfully
Jun 8 08:25:41 raspberrypi kernel: [ 5.668558] videodev: Linux video capture interface: v2.00
Jun 8 08:25:41 raspberrypi kernel: [ 5.699530] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 5.735352] bcm2835_audio bcm2835_audio: card created with 8 channels
Jun 8 08:25:41 raspberrypi kernel: [ 6.016897] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
Jun 8 08:25:41 raspberrypi kernel: [ 6.032609] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.041734] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.043823] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.059705] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
Jun 8 08:25:41 raspberrypi kernel: [ 6.094463] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.096172] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.096372] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.113798] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Jun 8 08:25:41 raspberrypi kernel: [ 6.137366] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
Jun 8 08:25:41 raspberrypi kernel: [ 6.150383] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
Jun 8 08:25:41 raspberrypi kernel: [ 6.151129] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
Jun 8 08:25:41 raspberrypi kernel: [ 6.152087] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
Jun 8 08:25:41 raspberrypi kernel: [ 6.152130] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.152155] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.152174] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.152204] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.152734] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Jun 8 08:25:41 raspberrypi kernel: [ 6.152795] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Jun 8 08:25:41 raspberrypi kernel: [ 6.164183] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Jun 8 08:25:41 raspberrypi kernel: [ 6.164286] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Jun 8 08:25:41 raspberrypi kernel: [ 6.164980] rpivid feb10000.codec: Device registered as /dev/video19
Jun 8 08:25:41 raspberrypi kernel: [ 6.180700] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Jun 8 08:25:41 raspberrypi kernel: [ 6.180779] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Jun 8 08:25:41 raspberrypi kernel: [ 6.185920] i2c i2c-22: Added multiplexed i2c bus 0
Jun 8 08:25:41 raspberrypi kernel: [ 6.191664] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
Jun 8 08:25:41 raspberrypi kernel: [ 6.192476] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
Jun 8 08:25:41 raspberrypi kernel: [ 6.195488] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
Jun 8 08:25:41 raspberrypi kernel: [ 6.196334] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
Jun 8 08:25:41 raspberrypi kernel: [ 6.196387] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
Jun 8 08:25:41 raspberrypi kernel: [ 6.198402] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
Jun 8 08:25:41 raspberrypi kernel: [ 6.198448] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.198473] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.198492] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.198509] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Jun 8 08:25:41 raspberrypi kernel: [ 6.202793] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
Jun 8 08:25:41 raspberrypi kernel: [ 6.202793] i2c i2c-22: Added multiplexed i2c bus 10
Jun 8 08:25:41 raspberrypi kernel: [ 6.202859] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
Jun 8 08:25:41 raspberrypi kernel: [ 6.203815] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
Jun 8 08:25:41 raspberrypi kernel: [ 6.867436] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jun 8 08:25:41 raspberrypi kernel: [ 6.925991] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
Jun 8 08:25:41 raspberrypi kernel: [ 6.932151] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
Jun 8 08:25:41 raspberrypi kernel: [ 6.943870] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Jun 8 08:25:41 raspberrypi kernel: [ 6.948632] Console: switching to colour dummy device 80x25
Jun 8 08:25:41 raspberrypi kernel: [ 7.001237] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.163708] Registered IR keymap rc-cec
Jun 8 08:25:41 raspberrypi kernel: [ 7.174988] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
Jun 8 08:25:41 raspberrypi kernel: [ 7.181460] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
Jun 8 08:25:41 raspberrypi kernel: [ 7.198306] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Jun 8 08:25:41 raspberrypi kernel: [ 7.199787] usbcore: registered new interface driver brcmfmac
Jun 8 08:25:41 raspberrypi kernel: [ 7.202751] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.211382] Registered IR keymap rc-cec
Jun 8 08:25:41 raspberrypi kernel: [ 7.211600] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
Jun 8 08:25:41 raspberrypi kernel: [ 7.211832] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input3
Jun 8 08:25:41 raspberrypi kernel: [ 7.225789] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.226430] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.226917] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.227436] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.227946] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.228246] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.228695] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
Jun 8 08:25:41 raspberrypi kernel: [ 7.272417] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
Jun 8 08:25:41 raspberrypi kernel: [ 7.352885] Console: switching to colour frame buffer device 240x67
Jun 8 08:25:41 raspberrypi kernel: [ 7.352959] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
Jun 8 08:25:41 raspberrypi kernel: [ 7.457068] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
Jun 8 08:25:41 raspberrypi kernel: [ 7.810936] uart-pl011 fe201000.serial: no DMA platform data
Jun 8 08:25:41 raspberrypi kernel: [ 8.159979] 8021q: 802.1Q VLAN Support v1.8
Jun 8 08:25:41 raspberrypi udisksd[450]: udisks daemon version 2.9.2 starting
Jun 8 08:25:41 raspberrypi kernel: [ 8.268199] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
Jun 8 08:25:41 raspberrypi kernel: [ 8.349338] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
Jun 8 08:25:41 raspberrypi kernel: [ 8.351018] bcmgenet fd580000.ethernet eth0: Link is Down
Jun 8 08:25:41 raspberrypi udisksd[450]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Jun 8 08:25:42 raspberrypi udisksd[450]: Failed to load the ‘mdraid’ libblockdev plugin
Jun 8 08:25:42 raspberrypi lightdm[522]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 8 08:25:42 raspberrypi udisksd[450]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 8 08:25:43 raspberrypi kernel: [ 9.635497] ov9281 10-0060: Detected OV009281 sensor
Jun 8 08:25:43 raspberrypi kernel: [ 9.635547] ov9281 10-0060: Consider updating driver ov9281 to match on endpoints
Jun 8 08:25:43 raspberrypi kernel: [ 9.795653] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Jun 8 08:25:44 raspberrypi kernel: [ 11.421771] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jun 8 08:25:44 raspberrypi kernel: [ 11.421816] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jun 8 08:25:45 raspberrypi lightdm[658]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Jun 8 08:25:48 raspberrypi kernel: [ 15.455953] Bluetooth: Core ver 2.22
Jun 8 08:25:48 raspberrypi kernel: [ 15.456061] NET: Registered PF_BLUETOOTH protocol family
Jun 8 08:25:48 raspberrypi kernel: [ 15.456067] Bluetooth: HCI device and connection manager initialized
Jun 8 08:25:48 raspberrypi kernel: [ 15.456084] Bluetooth: HCI socket layer initialized
Jun 8 08:25:48 raspberrypi kernel: [ 15.456092] Bluetooth: L2CAP socket layer initialized
Jun 8 08:25:48 raspberrypi kernel: [ 15.456107] Bluetooth: SCO socket layer initialized
Jun 8 08:25:48 raspberrypi kernel: [ 15.472205] Bluetooth: HCI UART driver ver 2.3
Jun 8 08:25:48 raspberrypi kernel: [ 15.472247] Bluetooth: HCI UART protocol H4 registered
Jun 8 08:25:48 raspberrypi kernel: [ 15.472373] Bluetooth: HCI UART protocol Three-wire (H5) registered
Jun 8 08:25:48 raspberrypi kernel: [ 15.472626] Bluetooth: HCI UART protocol Broadcom registered
Jun 8 08:25:49 raspberrypi kernel: [ 15.781512] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 8 08:25:49 raspberrypi kernel: [ 15.781533] Bluetooth: BNEP filters: protocol multicast
Jun 8 08:25:49 raspberrypi kernel: [ 15.781548] Bluetooth: BNEP socket layer initialized
Jun 8 08:25:49 raspberrypi kernel: [ 15.790650] Bluetooth: MGMT ver 1.22
Jun 8 08:25:49 raspberrypi kernel: [ 15.802632] NET: Registered PF_ALG protocol family
Jun 8 08:25:49 raspberrypi kernel: [ 15.920322] Bluetooth: RFCOMM TTY layer initialized
Jun 8 08:25:49 raspberrypi kernel: [ 15.920354] Bluetooth: RFCOMM socket layer initialized
Jun 8 08:25:49 raspberrypi kernel: [ 15.920377] Bluetooth: RFCOMM ver 1.11 -
I set my config.txt file as follow:
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
#camera_auto_detect=1
display_auto_detect=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
dtoverlay=ov9281
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
- What help do you need?
As you see in the log, I got " Jun 8 06:36:59 raspberrypi kernel: [ 9.601518] ov9281 10-0060: Consider updating driver ov9281 to match on endpoints"
How can I fix this?
