Hi all, I’m stuck trying to install the 64MP Pi Hawk-Eye camera driver on my Raspberry Pi and the kernel driver just won’t go in. The installer keeps failing because it can’t find a matching package for my kernel. I’m on kernel 5.15.73-v8+. Do you know of any way to roll a kernel back so the driver will install?
The installer prints:
“Cannot find the corresponding package, please send the following information to [email protected]”
That confirms it. The 64MP Pi Hawk-Eye driver simply has no build for kernel 5.15.73. The driver for 64mp doesn’t support kernel version 5.15.73, which is why the installer can’t locate a corresponding package — it’s matching your kernel against that links file and coming up empty.
Let’s see the raw installer log too, just to be sure nothing else is failing before the kernel check.
After that it detects the kernel, finds no matching entry, and prints the “Cannot find the corresponding package” + “unsupported kernel version” messages.
Thanks, that lines up exactly with what we expected. The installer downloads the links file fine, then parses it looking for your kernel version, and 5.15.73-v8+ just isn’t in the list, so it bails out.
The recommended solution here is to re-burn the bullseye system and then try to install the driver again on a stock kernel. Note the installer’s own warning: don’t run rpi-update.
In the meantime, since you asked about rolling back — the cleaner path is just to get onto a supported kernel. If you don’t want to re-image, some users have had luck rolling the kernel back instead.
That rolled back the kernels for me and then the driver installed fine. You might want to make a note for others who are on 5.15.73-v8+ — the rollback is a lot less hassle than re-imaging.
For reference my setup is a Raspberry Pi (bullseye-arm64), 64mp Pi Hawk-Eye camera, kernel 5.15.73-v8+.
Nice find, glad that got you unstuck. I’ll record that workaround — reinstalling raspberrypi-bootloader/raspberrypi-kernel to roll back to a supported kernel (and avoiding rpi-update) is a useful note for anyone hitting the missing 5.15.73 build.
Quick recap of the root cause for the thread: the 64MP Pi Hawk-Eye driver has no package for kernel 5.15.73-v8+ (bullseye-arm64-v5), so the installer reports “Cannot find the corresponding package” and flags the unsupported kernel. Get onto a supported kernel — re-burn official bullseye or roll the kernel back — and the install goes through.
Anything else you’re stuck on? If you’re moving to a 64-bit install, just ask.
One more thing while I have you — the documentation doesn’t say if a 64bit piOS install is ok. Is it ok? I was thinking of trying a 64-bit Raspberry Pi OS image with the 64mp Pi Hawk-Eye driver.
Yes, a 64-bit Raspberry Pi OS install is fine for this. Just make sure you use the official image rather than an rpi-update’d kernel, and pick one whose kernel version actually has a build in the links file. If it installs without the “unsupported kernel version” message, you’re good.
Also, as a quick follow-up: after you ran the install, could you paste what the driver install script printed? We can confirm it completed correctly.
Here’s what the install script output — is this normal?
Release/install_driver.sh
Release/uninstall_driver.sh
Installing DW9807 and ARDUCAM_64MP_EEPROM and ...
Your camera is ,and the relevant drivers have been installed.
It mentions DW9807 and ARDUCAM_64MP_EEPROM drivers and there are install_driver.sh / uninstall_driver.sh scripts in the release. The “Your camera is ,and…” line looks a little odd with the blank in the middle, so I wasn’t sure if that’s the expected output or if something didn’t register.
That output is the normal install flow — it’s unpacking the release, installing the DW9807 and ARDUCAM_64MP_EEPROM drivers, and running install_driver.sh. The blank in the “Your camera is ,and the relevant drivers have been installed” line is just a cosmetic quirk of the message; it doesn’t mean the driver failed.
The real way to verify the driver is to test the camera stream. Try this command:
libcamera-still -t 0
Could you manage to open the video streaming? If so, the driver is installed successfully.
Ran libcamera-still -t 0 and the preview/stream came up fine. So it looks like the driver is working now that I’m on a supported kernel. Thanks for the help!
That confirms it — if the video stream opens, the driver installed successfully.
Summary for anyone finding this thread later:
The 64MP Pi Hawk-Eye (pi hawk eye) driver has no build for kernel 5.15.73-v8+ (bullseye-arm64-v5). The installer’s links file only lists 5.10.17/5.10.63/5.10.92/5.10.103 and 5.15.30/5.15.32/5.15.56/5.15.61 — no 5.15.73 — so the install fails with “Cannot find the corresponding package” and the “unsupported kernel version” warning.
Fix: get onto a supported kernel. Either re-burn official bullseye and reinstall the driver, or roll the kernel back with sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel. Do not run rpi-update.
64-bit piOS is fine to use, as long as the kernel version has a matching build.
Verify the install by running libcamera-still -t 0; if the stream opens, the driver is good.
