I had used multiple camera adapters for my project. I was able to see the 3 cameras working through C++ ./previewOpencv. Then I tried to run the AdapterTestDemo.py.
This is the error message I received. Does anyone know why?
Start testing the camera D
[0:05:39.416330678] [1251] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
I also run the sudo i2cdetect -y 1 And here is the result.
You can check if there is any problem with the camera wiring of channel 4. Or swap the cameras of channel 1 and channel 4. Then observe whether the camera of channel 1 can operate normally.
If four channels show the same error. It may be that the cable from the CSI interface to the adapter board is not properly connected. Can you send me a photo of the connecting cable of the adapter board?
