However, if I activate the hardware PWM on the 33 pin Jetson Nano using jetson-io.py, the device-tree is updated again and the lines appear in /boot/extlinux/extlinux.conf:
LABEL JetsonIO
MENU LABEL Custom 40-pin Header Config
LINUX /boot/arducam/Image
FDT /boot/kernel_tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
I need to use the camera and the PWM at the same time. What can I do? Thank you.
Steps, what should I change in tegra210-p3448-0000-p3449-0000-b00-imx477.dts file (so I need this file too) to enable PWM on 33 pin in tegra210-p3448-0000-p3449-0000-b00-imx477.dtb
If you are using L4T32.6.1, you can use /opt/arducam/jetson-io/jetson-io.py to set GPIO.
If you are using a version prior to L4T32.6.1, then you can try to move the dtb file in the /boot/dtb/ directory to another directory to make a backup, then copy /boot/arducam/tegra210-p3448-0000-p3449-0000-b00-imx477.dtb to /boot/dtb, and then run jetson- io.
My L4T version is 32.5.1:
$ cat /etc/nv_tegra_release
R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t210ref, EABI: aarch64, DATE: Fri Feb 19 16:45:52 UTC 2021
I have jetson-io.py only in /opt/nvidia/jetson-io/ folder and don’t have /opt/arducam/ folder. Does it present only for L4T32.6.1 and newer or you meant /opt/nvidia folder?
I think I got your idea: .dtb file in /boot/dtb it is the base device tree file for Jetson Nano and jetson-io.py uses this file as a base and changes it in order to configure 40-pin-header. If I make back-up of /boot/dtb/kernel_tegra210-p3448-0000-p3449-0000-b00.dtb file and replace boot/dtb/kernel_tegra210-p3448-0000-p3449-0000-b00.dtb with device tree from Arducam for imx477, then jetson-io.py will make changes to this file and make possible to use <imx477 device tree> + <changes for PWM usage>. Am I right?
Thank you. I will try it later and report. However, in future we may need to construct our own .dts file for Jetson Nano. So is it real to get tegra210-p3448-0000-p3449-0000-b00-imx477.dts file in order to view changes and merge it with our own one?
Yes, /opt/arducam was added in L4T-R32.6.1.
you are right.
You can contact [email protected] or leave your email here, I will send the kernel patch to you.
