Hey everyone, I’m dealing with a pretty serious email problem right now. I’ve been missing important business emails - they just never show up in my inbox. And when I try to send emails out, a lot of them fail to go through. This has been going on for several days and clients are starting to call me asking why I haven’t responded. Kind of freaking out here. Anyone have any ideas?
That sounds frustrating, especially when it’s affecting business. Let’s start with the basics - what email app are you running, what phone are you on, and which carrier are you using? Also, are the missing emails from particular senders or does it seem totally random? Any error messages when the send fails?
I’m using Outlook for Android on a Samsung Galaxy phone, Verizon network. As for the missing emails, it seems random as far as I can tell. The only reason I know I’m missing them is because clients follow up asking why I haven’t replied. The send failures are intermittent too - sometimes it works, sometimes it just sits in the outbox forever with no real error message.
Got it, thanks for those details. Let me also follow up on the camera module case we’ve been working on - I did receive the picture you sent over and it was actually really helpful for diagnosis. Quick question on that front: are you running Linux or Windows with the camera module? I haven’t been able to determine that from what we’ve discussed so far.
Oh right, the camera too. Yeah I sent that picture showing how I’ve got everything connected up. As for which OS, honestly I’m not really sure what to tell you there. I’ve been trying it on a couple different computers. What exactly do you need to know?
No problem, let me clarify. The troubleshooting path is different depending on whether you’re on Linux or Windows, so I need to know which operating system you’re running when you’re trying to use the camera. Since I can’t determine that from what we have so far, I’m going to prepare guidance for both operating systems so you’re covered either way.
Okay that makes sense. I’ve got one machine running Linux Mint and another one with Windows 11. I’ve tried plugging the camera into both but couldn’t get it working on either. It’s like the system just doesn’t see it properly.
Alright, that gives us a good starting point. For both Linux and Windows, the first thing we need to do is verify whether the UVC camera is actually being recognized by the operating system at all. I’d recommend going through the steps in the UVC Camera Software Instructions here:
That guide covers both Linux and Windows usage. The critical section is the first one - identifying the video node, supported resolutions, and frame rates. On Linux you’d be looking at /dev/video* devices, and on Windows you’d check Device Manager or use the tools referenced in the docs. Can you run through those identification steps on both machines and let me know what you find?
Okay, I went through the documentation and did some checking. On Linux Mint, when I plug the camera in I do see /dev/video0 and /dev/video1 show up. But I can’t tell which one is actually the camera I’m trying to use. On the Windows 11 side, it does appear in Device Manager under ‘Cameras’ but there’s a yellow exclamation mark next to it. So something seems off on both.
That’s actually useful progress. Seeing /dev/video0 and /dev/video1 appear on Linux is a good sign - it means the hardware is being detected at the USB level at least. To figure out which video node is your UVC camera, you’ll want to use the v4l2-ctl commands shown in that documentation. Run those against each video node to list supported resolutions and frame rates - that’ll tell you which one is the camera and whether it’s enumerating its capabilities correctly.
On the Windows side, that yellow exclamation mark usually points to a driver or enumeration problem. The documentation covers how to inspect UVC descriptors on Windows too.
Where we’re at right now: the root cause hasn’t been pinned down yet. We’re still at the stage of verifying whether the camera module is being properly recognized by the OS. The key thing we need to confirm before moving forward is whether the video node, supported resolutions, and frame rates can actually be identified. If the camera can’t even enumerate those capabilities, that tells us one thing - if it can, we look elsewhere. Give those checks a try and share what output you get.
