Hey everyone, I’m trying to get the IMX708 PiCam 3 module working on my Jetson Orin Nano Developer Kit. I ran the full_install script from Arducam and it fails right away with this:
Kernel version: 5.15.148-tegra-36.4.2-20241212160716
Jetson type: NVIDIA Jetson Orin Nano Developer Kit
I’m on kernel 5.15.148-tegra-36.4.2-20241212160716. Also been having some issues with jetson-io.py not behaving as expected, though that might be a separate thing. Is there any documentation for manually setting up the camera driver? The automated script clearly isn’t covering my kernel version.
Thanks for posting the kernel version and Jetson type — that’s exactly what we need to diagnose this. The issue is that the standard driver installer doesn’t have a pre-built deb package for your kernel (5.15.148-tegra-36.4.2-20241212160716). It’s a compatibility gap — the installer looks for a matching package, can’t find one, and bails out.
Take a look at the troubleshooting guide here, specifically the section on camera driver installation failures on Jetson devices:
That should walk you through getting the right driver for your setup. Regarding the jetson-io.py issues, if you can share more specifics (errors, what you’re trying to do), I can help with that too.
Alright, so I followed the troubleshooting guide and upgraded JetPack on the Orin Nano. After that, I re-ran the driver installation script. It gets further this time — it successfully downloads imx708_links.txt (11353 bytes) and resolves github.com fine. But then it tries to pull down this deb package:
Resolving github.com... 140.82.113.4
Connecting to github.com|140.82.113.4|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2025-08-07 19:06:56 ERROR 404: Not Found.
What’s confusing me is that the deb package filename references kernel 5.10.192-tegra-35.5.0, which definitely isn’t what I’m running after the JetPack upgrade. The connection to github.com is fine — DNS resolves and the TCP handshake completes — so it’s not like I’m offline. The file just isn’t there. Is there a different package URL I should be using for the upgraded JetPack?
Looking at your output, the 404 error points to a network connection issue on the Jetson Orin Nano side rather than a missing file. Even though the initial DNS resolution and TCP connection to GitHub succeed, an unstable or intermittent connection can cause the HTTP request to fail partway through, resulting in a 404 from their CDN.
Can you double-check the internet connection on the Jetson? Try a few things:
Run ping -c 10 github.com and make sure there’s no packet loss
Try wget on a known-good file to verify downloads work reliably
If you’re on Wi-Fi, try switching to Ethernet if possible, or vice versa
Once you’ve confirmed a stable connection, re-run the installer script and let me know if the 404 persists.
