Cannot install IMX477 camera driver on Jetson Nano - no matching deb package for kernel 4.9.337-tegra-32.7.4
Hi, I’m trying to install the Arducam IMX477 driver on a Jetson Nano Developer Kit and the installer keeps failing with “Cannot find the corresponding deb package”.
Command I ran:
./install_full.sh -m imx477
Relevant output:
./install_full.sh: line 19: warning: command substitution: ignored null byte in input
NVIDIA Jetson Nano Developer Kit
wget downloaded https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/modules.txt (Length: 1346) - saved [1346/1346]
wget downloaded https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/imx477_links.txt (Length: 12196) - saved [12196/12196]
Cannot find the corresponding deb package, please send the following information to support
Kernel version: 4.9.337-tegra-32.7.4-20230608212426
Jetson type: NVIDIA Jetson Nano Developer Kit
It downloads modules.txt and imx477_links.txt fine, so the network side seems okay. Any idea why it can’t match a deb?
Thanks for the full output. The null byte warning on line 19 is from a command substitution and is usually harmless — the script continues and downloads both index files. The real failure is in the deb lookup step.
Can you also run these two commands and paste the output?
uname -r
cat /etc/nv_tegra_release
The deb packages are matched against the L4T release, not just the board name, so I want to confirm the exact release you’re on.
Sure, here you go:
uname -r
R32 (release), REVISION: 7.4, GCID: 32984718, BOARD: t210ref, EABI: aarch64, DATE: Thu Jun 8
So it looks like L4T 32.7.4.
Right, that’s the issue. Arducam hasn’t released an IMX477 driver deb for L4T 32.7.4 yet. The imx477_links.txt index has entries for supported releases, and 32.7.4 isn’t one of them, so install_full.sh reaches the end of the lookup and falls through to the “Cannot find the corresponding deb package” message.
There isn’t a deb to force-install for 32.7.4; you need to flash a JetPack/L4T version that’s on Arducam’s supported list:
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/
For the Nano, 32.7.1 is the one I’d use while 32.7.4 is not supported.
Thanks, that explains it. I flashed JetPack 32.7.1 and now ./install_full.sh -m imx477 completes without the deb lookup error, so the driver installed fine.
But now I’ve hit a second problem. The preview command from the quick start guide doesn’t work for this camera. The guide’s preview uses v4l2src, but the IMX477 is a Bayer camera, so I suspect v4l2src isn’t suitable. Is there a different pipeline I should use?
Guide link: Quick-Start-Guide - Arducam Wiki
You’re right — the IMX477 is a Bayer sensor, so the v4l2src preview path in that guide won’t work for it. Use nvarguscamerasrc instead, which goes through the proper ISP/debayer path on Jetson.
Try this:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=(fraction)30/1’ ! nvvidconv ! videoconvert ! xvimagesink
That pipeline works — I’m getting a 1080p30 preview now. Thanks.
One thing worth flagging: the quick start guide still shows the v4l2src command under the preview section, so it’s misleading for the IMX477.
Glad that sorted it. I’ve flagged the quick start guide to be corrected to use nvarguscamerasrc for the IMX477 preview.
For anyone else hitting this: L4T 32.7.4 (kernel 4.9.337-tegra-32.7.4) doesn’t have a matching IMX477 driver deb, so flash a supported release such as 32.7.1 first; then use nvarguscamerasrc rather than v4l2src for the IMX477 preview.
