Hi all, I’m stuck trying to get an image from the integrated camera on my Arducam unit. I just received the equipment and I can’t get any video feed at all from the camera. I’ve been pulling my hair out over this. Looking at the SD card that came with it, I’m starting to think the factory image on it might be corrupted or something. Does anyone know where I can download the original image that’s supposed to ship on these SD cards? I’ve attached a screenshot of what I’m dealing with.
Welcome to the forum. Can you give us a bit more detail about what you’re seeing? Does the unit appear to power on at all — any LEDs, fan spin, anything like that? And when you say no image, do you mean a completely blank screen, or is there some kind of output that just doesn’t include the camera feed? Also, if you can share the model number of your Arducam unit, that would help narrow things down.
Yeah, so the unit does power on — I can see the status LED lit up and it seems like the system is booting. But when it comes to the camera, there’s just nothing. Black screen where the video feed should be. No error messages either, which is what’s making this so frustrating. I’ve tried reseating the SD card and power cycling a few times, same result every time. My gut says the SD card wasn’t flashed properly at the factory or the image got corrupted somehow. I really just need to start fresh with a known-good image.
That does sound like a corrupted or incomplete factory image on the SD card — it matches what we’ve seen before with similar cases. The good news is the original factory image for these Arducam units is publicly available. It’s hosted on SourceForge under the “kingkong” project. You can grab it from here:
Once downloaded, you’ll need to reflash it onto your SD card. A few tips:
- Use balenaEtcher or Rufus if you’re on Windows, or dd if you’re on Linux/Mac
- Do a full format (not quick format) on the SD card first to rule out filesystem-level issues
- After flashing, make sure to safely eject before removing the card
- It’s also worth trying a different SD card if you have one handy — sometimes the card itself can be faulty
Thanks for the link! I downloaded the image from the kingkong project and flashed it onto the SD card using balenaEtcher. Did the full format beforehand like you suggested. Unfortunately, I’m still not getting any camera feed after booting up with the freshly flashed card. Starting to wonder if it’s not the SD card at all. Could there be a hardware issue, like the camera ribbon cable or something? Anything else I should try before I lose my mind over this?
Good call on checking the hardware side. A few things to investigate next:
Ribbon cable connection — The flexible ribbon cable for the camera module can sometimes come loose during shipping. Open the unit and gently reseat both ends of the camera ribbon cable, making sure it’s fully inserted and the connector latch is locked down.
Verify the image flash — It’s worth confirming the image actually wrote correctly. If you’ve got a way to read the SD card back and compare a checksum against the downloaded image file, that would rule out a bad flash.
Try another SD card — Even a brand new card can be problematic. If you have a known-good Class 10 SD card (preferably 16GB or 32GB), try flashing the kingkong image to that one instead.
To summarize where we’re at: the factory image from the kingkong project on SourceForge is the correct baseline image for your unit. We’ve ruled out the image source being the problem. The next step is isolating whether it’s the SD card hardware, the flashing process, or a physical connection issue with the camera module itself. Let us know what you find after checking those three things.
