Cannot find imx519_kernel_driver package for Raspberry Pi kernel 6.1.19-v8+ (c03114)
Hi all, I’m trying to get my Arducam IMX519 set up on a Pi and the installer keeps failing at the driver step. It prints this:
Hardware Revision: c03114
Kernel Version: 6.1.19-v8+
Package: imx519_kernel_driver – bullseye-v5
You are using an unsupported kernel version, please install the official SD Card image (do not execute rpi-update): https://www.raspberrypi.com/software/operating-systems/
I’m not really sure what to do with this — does that mean my Pi is too new or too old? Any help appreciated.
Thanks for posting the full output — that’s actually really helpful. The second message is the important one. The imx519_kernel_driver bullseye-v5 package is built for specific supported kernel versions, and 6.1.19-v8+ isn’t one of them, so the installer can’t find a matching package. Just to confirm: did you run rpi-update on this card, or is this a custom/prebuilt image? The Quick Start Guide here has the expected setup flow: Quick Start Guide - Arducam Wiki
I inherited this SD card from another project, so I honestly don’t know its full history. rpi-update may well have been run on it at some point. So the issue is just that this kernel (6.1.19-v8+) isn’t supported by the bullseye-v5 package?
Right — that’s the root cause. The package only has prebuilt driver binaries for certain kernel versions, and your current kernel isn’t in that set. The cleanest fix is to flash the official Raspberry Pi OS image from Raspberry Pi OS downloads – Raspberry Pi and avoid running rpi-update afterwards. Then run through the native camera quick start guide again and the package lookup should succeed.
Okay, that makes sense. I’ll reflash with the official image, skip rpi-update this time, and report back. Thanks.
Just wanted to update — I reflashed the official image and the imx519_kernel_driver package installed without any issues this time. Camera is detected and working.
Now I’ve hit a different problem though. I’m trying to put the Arducam live stream onto a Node-RED dashboard. On my phone, VLC opens the stream URL and plays it fine. But in Chrome on the desktop, instead of showing the stream it just downloads a file. Is there a setting or a different URL format I should be using?
Good to hear the driver install is sorted. For the Chrome problem — can you tell me how the stream is being served? What container/codec is the stream URL delivering (MJPEG, H.264 over RTSP, etc.)? Chrome will happily download a stream as a file when it can’t natively play that container/codec inline, which would explain why VLC works but the browser doesn’t.
I’m not entirely sure about the container details, to be honest. The camera exposes a stream URL and I just pointed the dashboard at it. VLC handles it automatically, so I never had to dig into what format it actually is. What should I check?
Got it. I should be upfront here — getting a stream to play inline in Chrome is a bit outside what we can directly support, since we don’t have hands-on experience with the browser-side playback configurations. What VLC playing it tells us is that the stream itself is fine; the issue is purely browser-side. Chrome needs the right MIME type and container (or a player that can handle it, e.g. via MSE/HLS) to render it in a
Understood — so the stream works (VLC proves that), it’s just that Chrome needs a browser-specific approach to display it inline rather than downloading it. I’ll look into the container/MIME side and ask around web streaming folks. Thanks for the pointers.
Exactly right. The camera and stream are fine — it’s the browser player implementation that needs the right approach. If you sort out a working setup, feel free to drop it back in this thread so it helps the next person. Good luck!
