Hardware Revision: d03115
Kernel Version: 5.10.60-v7l+
Package: imx519_kernel_driver -- buster
You are using an unsupported kernel version, please install the official SD Card image(do not execute rpi-update):
https://www.raspberrypi.com/software/operating-systems/
The IMX519 can currently only be used on the Raspberry Pi Bullseye system, and your error is showing the Buster package. The Buster kernel is no longer supported for the IMX519 camera, so the installer can’t find a matching package.
So the main problem is still the kernel driver failing to install, and it’s happening on my Pi 4. Here’s where I’m at:
Platforms I have: Raspberry Pi 3, 4 and Zero (I mainly need to get the Pi 4 and Pi 3 working first).
Camera: Arducam 16MP IMX519 autofocus camera module for RPi.
After installing the kernel driver on the Pi 4, I get:
Kernel Version: 5.15.45-v7l+
Thanks, that helps. Look closely at the error you sent: Package: imx519_kernel_driver -- buster. That means the system is still reporting Buster, which tells me you’re on the wrong/unsupported system.
To confirm, I need to know your current system information and config file. Please send me the output of the same commands:
# http://rpf.io/configtxt
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
start_x=1
gpu_mem=128
dtoverlay=vc4-kms-v3d
I’m still getting the same error. I moved the downloaded file into /home/pi and also /home/pi/Downloads, but I’m not sure if that’s even the right location. I still can’t see dtoverlay=imx519 anywhere.
Error:
cat /boot/config.txt is the same as before — still no dtoverlay=imx519 line.
I also attached a screenshot of the files present on the system to show what I moved:
That’s a bit odd — you mentioned downloading the Bullseye image locally, but the system is still showing Buster. On our side we’ve tested the installation file and it works without issue, so something doesn’t line up here.
I’ll need to test according to your operating environment and process, and confirm this with our software engineer. Please give me a bit of time to check with them — I’ll follow up once I hear back.
I downloaded the Bullseye image but I’m not sure what to do with it next. I think this might be the real issue I need to sort out before the driver will install. Any advice?
That’s very likely the missing piece. The file you downloaded (raspios_full_armhf-2022-04-07) is a disk image, not something you copy onto the running system — that’s why dropping it into /home/pi or /home/pi/Downloads did nothing. It has to be flashed to an SD card using Raspberry Pi Imager or balenaEtcher, and then you boot the Pi from that SD card. Only then will /etc/os-release report Bullseye instead of Buster.
To recap where we are:
Your logs keep showing Package: imx519_kernel_driver -- buster, and /etc/os-release confirms VERSION_CODENAME=buster — so the Pi is still running Buster.
/boot/config.txt has no dtoverlay=imx519, which confirms the driver never installed successfully.
Copying the image into /home/pi or /home/pi/Downloads has no effect — it must be flashed to the SD card and booted.
Next step: flash the Bullseye image to an SD card, boot from it, confirm cat /etc/os-release shows bullseye, then run ./install_pivariety_pkgs.sh -p imx519_kernel_driver again and check that dtoverlay=imx519 appears in /boot/config.txt.
Also, I’m still waiting on our software engineer to confirm the Buster discrepancy on our end — I’ll get back to you on that part when I have an answer.
