That error usually means the installer script couldn’t find a prebuilt deb that matches your exact kernel build. Could you post a few details so we can narrow it down? Run uname -r and also check /etc/nv_tegra_release, and let us know which Jetson board you’re using.
Sure. It’s a Jetson AGX Orin Developer Kit. uname -r gives:
5.10.192-tegra-35.5.0-20240613202628
And L4T is r35.5.0. I also went digging through the Arducam GitHub releases and the newest deb I can find for r35.5.0 is 5.10.192-tegra-35.5.0-20240308084144.deb. Would that one work even though the kernel build string doesn’t match?
Thanks for that. Looking at your kernel 5.10.192-tegra-35.5.0-20240613202628, there isn’t a publicly available deb built for that exact build string on L4T r35.5.0, which is why the installer can’t locate one. The 5.10.192-tegra-35.5.0-20240308084144.deb isn’t a guaranteed match since the kernel build differs. The cleanest path would be to move to JetPack 6.0 / L4T 36.3.0, which has matching packages and will also improve performance, then re-run the install from the quick start guide.
Hmm, that’s a bigger change than I was hoping for. I’d really rather not reflash the whole board to JetPack 6.0 right now if I can avoid it. Is there any other option, or is reflashing the only way?
I understand, reflashing isn’t always convenient. Let me check with our team to see if there’s a build available for your exact kernel instead. Give me a bit.
Good news - I was able to get a matching package put together for your setup. I’ve sent you the installation package via private message, so please check your messages. It’s specifically built for the Jetson AGX Orin (t234), L4T 35.5.0, kernel 5.10.192-tegra-35.5.0 build 20241213174244, targeting the imx477 sensor.
To install, copy the package onto the Jetson and run:
Then reboot and test the camera. The key thing here is that the imx477 driver deb has to match the kernel build exactly - your original 20240613202628 build didn’t have a public package, so the installer bailed out. This one is built for your board, so it should line up.
