Cannot find corresponding package libcamera on Raspberry Pi a020d3 Stretch kernel 4.19.66-v7+
Hi everyone, I’m stuck trying to install the camera library for my 16 MP camera. When I run the install command I just get this error:
“Error: cannot find the corresponding package, please send the following to ‘above email’”
I’m not really sure what’s going on. Has anyone else seen this?
Hello, thanks for posting. That error usually means the package you’re trying to install doesn’t have a matching build for your current setup. Could you share a few details so we can narrow it down?
  • Hardware revision
  • Kernel version (you can get it with uname -r)
  • Which package you’re trying to install, and the OS version you’re on
Sure, here’s what I have:
  • Hardware Revision: a020d3
  • Kernel Version: 4.19.66-v7+
  • Package: libcamera – stretch
Let me know if you need anything else.
Thanks, that helps a lot. Looking at your environment, you’re on a Stretch-based OS running kernel 4.19.66-v7+. The issue is that the libcamera package you’re trying to install simply has no corresponding package available for Stretch.
So it’s not a typo or a broken mirror — the package genuinely doesn’t exist for that OS version.
Ah okay, that makes sense. So the OS I’m running is just too old for this package? Is there a way around it, or do I need to do a full reinstall?
Correct. The root cause is that your installed OS/kernel version is too old (Stretch, kernel 4.19.66-v7+), so there’s no matching libcamera package available for it.
The recommended fix is to upgrade to the latest Bullseye OS, which runs kernel version 6.1.21.
Got it. So I should burn a fresh Bullseye image and then try the libcamera install again? Just want to make sure I do this in the right order.
Yes, that’s right. Here’s what I’d suggest:
  1. Burn the latest Bullseye OS image (kernel version: 6.1.21) to your SD card.
  2. Boot it up and confirm the kernel with uname -r.
  3. After burning Bullseye OS, retry the libcamera installation and give it a try.
That should get you past the “cannot find the corresponding package” error.
Perfect, I’ll reflash with Bullseye and test again. Thanks for walking me through it — I didn’t realize the older Stretch image was the problem.
No problem! Just to summarize for anyone else hitting the same thing: the 16 MP camera libcamera package requires the latest Bullseye OS (kernel 6.1.21) rather than the older Stretch OS (kernel 4.19.66-v7+).
If you’re on Stretch with kernel 4.19.66-v7+, that’s why the package can’t be found. Reflash with Bullseye and the install should work. Let us know how it goes after you’ve reflashed.
