Cannot find corresponding deb package when installing IMX477 driver on Jetson Nano
Hi everyone. I’m trying to set up the IMX477 camera on an NVIDIA Jetson Nano Developer Kit, following this video:
I ran the install script:
/install_full.sh
It detected the board as ‘NVIDIA Jetson Nano Developer Kit’, downloaded the package list, then stopped with this error:
Relevant output:
/install_full.sh: line 19: warning: command substitution: ignored null byte in input
–2023-08-03 16:56:11-- https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/imx477_stereo_links.txt
imx477_stereo_links 100%[===================>] 9.40K --.-KB/s in 0.02s
2023-08-03 16:56:12 (535 KB/s) - ‘imx477_stereo_links.txt’ saved [9627/9627]
Kernel version is 4.9.337-tegra-32.7.4-20230608212426. Any idea why the package isn’t found?
Thanks for the log. The download itself completed fine (9627 bytes), so this isn’t a network problem. The warning about the null byte is from the script’s command substitution on line 19, but it still managed to detect the board correctly. The failure happens later, when the script tries to match your kernel/L4T version against a deb in that downloaded list.
Can you confirm the exact L4T release? uname -r is a good start, but the script’s deb matching also cares about the JetPack/L4T version. If you’re on a newer 32.7.x build, it may simply not have a matching package.
uname -r returns:
4.9.337-tegra
The full version string I got earlier is 4.9.337-tegra-32.7.4-20230608212426, so it looks like L4T 32.7.4. I’m using the image that came from SDK Manager / the dev kit setup, I haven’t swapped kernels or anything.
That points to the likely cause. The script downloads imx477_stereo_links.txt from the v0.0.3 release and then tries to find a deb package that matches the installed kernel/L4T release. When there’s no entry for your kernel, it exits with ‘Cannot find the corresponding deb package’. So the message is really a JetPack/L4T compatibility mismatch rather than a generic install failure.
Can you check the supported JetPack versions listed here and see whether your 32.7.4 build is covered?
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/
Ah okay, so it’s probably that my JetPack version isn’t on the supported list. I’ll go through that documentation page and pick a supported release to reflash. I was hoping there was a way to make it work on 32.7.4, but it sounds like the installer just doesn’t have a matching deb for this kernel.
Right, I’d avoid forcing a mismatched deb. The driver packages are built against specific L4T releases, and installing the wrong one can fail to load or break the camera stack. The cleanest path is to use one of the JetPack versions from the ArduCAM docs page, reflash with that, and then rerun /install_full.sh.
To summarize: the script downloads imx477_stereo_links.txt successfully, then fails because there’s no matching deb for kernel 4.9.337-tegra-32.7.4-20230608212426. Root cause is JetPack/L4T incompatibility with the ArduCAM IMX477 driver. Verify the supported JetPack version at the docs link, install a supported one, and the script should be able to find the corresponding deb package.
