Hi everyone, I’m trying to get an IMX519 camera working on my NVIDIA Jetson Orin Nano Developer Kit, but when I try to install the driver I keep getting this error:
Has anyone run into this before? I’m not really sure what I’m doing wrong.
Thanks for the report. That error usually means the installer can’t match a driver package to your current JetPack/L4T version. Could you share your kernel version and confirm which Jetson board you’re using? You can grab the kernel version with:
Thanks, that gives us what we need. Looking at the kernel string, your board is running L4T 36.2.0. Unfortunately, the camera driver for L4T 36.2.0 hasn’t been released yet by Arducam, which is exactly why the installer can’t find the corresponding deb package.
So to be clear, the root cause is the L4T version, not anything wrong with the camera or the board itself. Camera driver availability is tied to the L4T/JetPack version, and 36.2.0 isn’t supported yet.
The cleanest fix is to burn the OS to a supported JetPack version before installing the camera driver. The supported versions are listed in the “Official NVIDIA Orin Nano Development Kit” section of the Arducam docs here:
Pick one of the JetPack/L4T versions listed there and flash it with the NVIDIA SDK Manager. After that, the installer should be able to find the matching deb package.
You’re welcome. Just to recap: this is purely a JetPack/L4T version issue. L4T 36.2.0 isn’t supported by the Arducam driver yet, so reflashing to a listed version is required before the corresponding deb package can be found and installed. Let us know how it goes after the reflash.
