Cannot find 64mp_pi_hawk_eye_kernel_driver package for kernel 5.15.84-v8+ on hardware revision d03115
Hi everyone. I’m trying to install the Arducam 64MP Hawk Eye driver on my Pi 4 and the install script keeps failing. It prints:
Hardware Revision: d03115
Kernel Version: 5.15.84-v8+
Package: 64mp_pi_hawk_eye_kernel_driver – bullseye-arm64-v5
You are using an unsupported kernel version, please install the official SD Card image(do not execute rpi-update)
Does the driver really not exist for 5.15.84-v8+, or am I doing something wrong?
We actually released a fresh 64MP driver build for kernel 5.15.84 today, so try the install again first and it may now match your kernel/package combination. One thing to note: 5.15.84-v8+ usually means the kernel came from rpi-update, not the standard Raspberry Pi OS image. If the package still isn’t found, flash the official Raspberry Pi OS image (do NOT run rpi-update) and then reinstall the Arducam camera driver.
Thanks. After reinstalling the driver, the package installs now, but libcamera-hello still says no cameras available. I’m on a Raspberry Pi 4, kernel 5.15.84-v8+, libcamera v0.0.2+55-5df5b72c.
First run:
Preview window unavailable
[0:01:02.645248535] [1368] INFO Camera camera_manager.cpp:299 libcamera v0.0.2+55-5df5b72c
[0:01:02.685048517] [1369] WARN CameraSensorProperties camera_sensor_properties.cpp:190 No static properties available for ‘arducam_64mp’
[0:01:02.685126665] [1369] WARN CameraSensorProperties camera_sensor_properties.cpp:192 Please consider updating the camera sensor properties database
[0:01:02.685221369] [1369] ERROR V4L2 v4l2_device.cpp:92 ‘dw9807 10-000c’: Failed to open V4L2 device ‘/dev/v4l-subdev1’: Invalid argument
[0:01:02.685278646] [1369] ERROR CameraSensor camera_sensor.cpp:501 ‘arducam_64mp 10-001a’: Lens initialisation failed, lens disabled
[0:01:02.703727313] [1369] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam_64mp.json’ not found for IPA module ‘raspberrypi’
[0:01:02.703837054] [1369] ERROR IPARPI raspberrypi.cpp:240 Could not create camera helper for arducam_64mp
[0:01:02.703886406] [1369] ERROR RPI raspberrypi.cpp:1303 Failed to load a suitable IPA library
[0:01:02.704124202] [1369] ERROR RPI raspberrypi.cpp:1228 Failed to register camera arducam_64mp 10-001a: -22
My /boot/config.txt had:
camera_auto_detect=1
display_auto_detect=1
dtoverlay=vc4-kms-v3d
max_framebuffers=2
arm_64bit=1
disable_overscan=1
gpu_mem=64
initramfs initrd.img-5.15.84-v8±overlay
dtoverlay=arducam_64mp
#dtoverlay=vc4-kms-v3d,cma-512
So I uncommented the cma line so it now has:
Rebooted, ran libcamera-hello again:
[0:03:07.855103012] [1701] INFO Camera camera_manager.cpp:299 libcamera v0.0.2+55-5df5b72c
What is the issue?
From that log, the sensor is being found on I2C, but libcamera fails to initialize it: it can’t open the dw9807 lens/VCM device (‘/dev/v4l-subdev1’: Invalid argument), the arducam_64mp IPA config/camera helper is missing, and camera registration fails with -22. That points to a driver/libcamera mismatch rather than a hardware fault. Let’s get a full diagnostic. Please reboot, then run:
It will generate arducam-bug-report.txt. Send me that file so I can see the full system state.
Okay, running it now. I’ll send the report over.
Thanks, got it. Before we go further, there’s a line I’ve highlighted in a screenshot from /boot/config.txt. Can you make sure that line is uncommented (released) and then re-run the bug-report script? It’s related to the vc4-kms-v3d/cma-512 entry.
I uncommented it and rebooted, then re-ran the script. Here’s the relevant output.
System: Raspberry Pi 4 Model B Rev 1.5, revision d03115, Debian 11 (bullseye), kernel 5.15.84-v8+. libcamera packages: libcamera-apps 0~git20230104+4fea2ee-1 arm64, libcamera-tools 0~git20230105+5df5b72c-1 arm64, libcamera0:arm64 0~git20230105+5df5b72c-1 arm64, python3-libcamera 0~git20230105+5df5b72c-1 arm64. CMA: CmaTotal 524288 kB, CmaFree 510100 kB.
libcamera-still --list-cameras returns: No cameras available!
libcamera-still -n -t 1000 -o arducam-test.jpg --width 1920 --height 1080 gives:
[0:30:56.724086214] [2321] INFO Camera camera_manager.cpp:299 libcamera v0.0.2+55-5df5b72c
[0:30:56.747257444] [2323] WARN CameraSensorProperties camera_sensor_properties.cpp:190 No static properties available for ‘arducam_64mp’
[0:30:56.747299056] [2323] WARN CameraSensorProperties camera_sensor_properties.cpp:192 Please consider updating the camera sensor properties database
[0:30:56.747351705] [2323] ERROR V4L2 v4l2_device.cpp:92 ‘dw9807 10-000c’: Failed to open V4L2 device ‘/dev/v4l-subdev1’: Invalid argument
[0:30:56.747378224] [2323] ERROR CameraSensor camera_sensor.cpp:501 ‘arducam_64mp 10-001a’: Lens initialisation failed, lens disabled
[0:30:56.758605090] [2323] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam_64mp.json’ not found for IPA module ‘raspberrypi’
[0:30:56.758674536] [2323] ERROR IPARPI raspberrypi.cpp:240 Could not create camera helper for arducam_64mp
[0:30:56.758694888] [2323] ERROR RPI raspberrypi.cpp:1303 Failed to load a suitable IPA library
[0:30:56.758843429] [2323] ERROR RPI raspberrypi.cpp:1228 Failed to register camera arducam_64mp 10-001a: -22
And arducam-test.jpg was not created.
dmesg | grep arducam:
[7.210422] arducam_64mp 10-001a: Device found Arducam 64MP.
[7.211340] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
dmesg camera-related lines:
[2.311491] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[7.040105] dw9807 10-000c: I2C write CTL fail ret = -121
[31.709198] cam-dummy-reg: disabling
config.txt now has dtoverlay=arducam_64mp and dtoverlay=vc4-kms-v3d,cma-512. The overlays arducam-64mp.dtbo and arducam_64mp.dtbo are present in /boot/overlays, and arducam_64mp.ko.xz plus dw9807-vcm.ko.xz are in /lib/modules/5.15.84-v8+/kernel/drivers/media/i2c.
Your report is really useful. The sensor is present (dmesg shows ‘Device found Arducam 64MP’) and the overlays/kernel modules are installed, but you’re still running the stock Raspberry Pi libcamera build (0~git20230105+5df5b72c-1). Stock libcamera doesn’t ship the arducam_64mp.json IPA config or the matching camera helper, and it isn’t driving the dw9807 correctly (that I2C write CTL fail ret = -121), which is why the camera never registers.
Install Arducam’s libcamera package following the getting-started section here:
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Libcamera-User-Guide/#getting-started
Then retry libcamera-still --list-cameras and libcamera-still.
Thank you, I can now capture images. But I still have warnings and an error on still, video and raw capture. libcamera is now v0.0.0+3897-c3c878a9.
libcamera-still -t 5000 -n -o test.jpg:
[0:33:40.049904354] [3361] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
[0:33:40.056181106] [3363] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for ‘arducam_64mp’
[0:33:40.056265346] [3363] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:33:40.075125844] [3363] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[0:33:40.075987560] [3363] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:33:40.076237354] [3363] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media4
[0:33:40.076941424] [3361] INFO Camera camera.cpp:1035 configuring streams: (0) 4624x3472-YUV420
[0:33:40.077349217] [3363] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[0:33:45.584709101] [3361] INFO Camera camera.cpp:1035 configuring streams: (0) 4624x3472-YUV420 (1) 4624x3472-SBGGR10_CSI2P
Still capture image received
libcamera-vid --autofocus runs until timeout (‘Halting: reached timeout of 5000 milliseconds.’), and libcamera-raw -t 2000 -o test.raw reports ‘Raw stream: 1280x720 stride 1600 format SBGGR10_CSI2P’, but they show the same WARN/ERROR lines. Should I be worried about those?
Glad it’s capturing. Those remaining messages are non-fatal and can be ignored. The ‘No static properties available for arducam_64mp’ warning and the ‘Mismatch between Unicam and CamHelper for embedded data usage’ warning are cosmetic for this sensor. The DelayedControls error for control id 0x009a090a just means that particular control isn’t exposed by /dev/v4l-subdev0, and it doesn’t stop capture. Your log shows the camera correctly registered to Unicam device /dev/media3 and ISP device /dev/media4, with the sensor at 4624x3472-SBGGR10, and you got ‘Still capture image received’. No further action needed.
