Hi, I’m using the Arducam 8MP IMX219 multi-camera kit for the Jetson AGX Orin (6x cam, model B0472). When I connect the cameras directly over CSI, everything works fine. But I need to place the cameras farther away, so I got the Ethernet extension kit. With the extension kit in the loop I can’t get any camera to enable or connect at all. Has anyone used the Ethernet extension kit with this IMX219 6x cam kit on the AGX Orin?
Can you clarify a couple of things first? You said direct CSI works - is that on the same Orin AGX with the same cameras? And with the extension kit, what exactly happens - does the device not enumerate, or does the pipeline just fail to start? Any dmesg output or error messages would help. Also, how is the extension kit connected - between the camera and the HAT, or between the HAT and the Jetson?
Yes, same Orin AGX, same cameras. Direct CSI connection works. With the extension kit, the connection just can’t be enabled - no camera comes up. I don’t have a useful dmesg output to share, and no specific error message shows up. I’ve already checked the CSI connections, checked the Jetson expansion header, made sure I’m using the right pins to connect the extension kit to the expansion header, and tried several different cameras. All the same result.
Thanks, that’s a good set of checks. Just to confirm the hardware: you’re using the Arducam IMX219 Multi-Camera Kit for the NVIDIA Jetson AGX Orin, 6x cam (B0472), correct? And the extension kit is the Arducam Ethernet extension kit?
Correct, it’s the Arducam 8MP IMX219 Jetson AGX Orin 6x cam B0472. I also have a Jetson Nano around, and I was hoping the same extension approach might work there too, but the immediate problem is on the AGX Orin.
Based on your description, I checked this configuration. The Arducam IMX219 Multi-Camera Kit for the NVIDIA Jetson AGX Orin is not compatible with the Ethernet extension kit. That matches what you’re seeing - direct CSI connections work, but the extension kit can’t be used with this multi-camera kit. Unfortunately there’s no workaround for that combination.
Understood. So is there any other combination that would work with the Ethernet extension kit? I’m open to using it with the Jetson Orin AGX or the Jetson Nano, and with a different multi-camera HAT or the Quad-Camera Kit. The goal is to get more distance between the camera and the HAT - not between the Jetson and the HAT.
For Jetson devices, we don’t support using the Ethernet extension kit with multi-camera HAT modules at all. That includes the use case where you want to extend the distance between the camera and the HAT. So there’s no supported combination with a multi-camera HAT or Quad-Camera Kit on either the Orin AGX or the Nano.
