Hi, I’m trying to get my rb-camera-ww camera working on my Raspberry Pi but I can’t download/install the library. I keep getting an error when I try to install libcamera-dev. Hoping someone here can help me figure out what’s going wrong.
Hi, sorry to hear you’re stuck. To point you in the right direction I’ll need a bit more info about your setup. Can you post:
- the exact command you ran
- the full error/output you get
- your Raspberry Pi hardware revision
uname -aoutput (kernel version)- which OS release you’re running (Jessie, Buster, Bullseye?)
That’ll tell us whether it’s a package/repo issue or something else.
Sure, here’s what I’ve got.
Hardware Revision: a02082
Kernel Version: 4.4.21-v7+
Package: libcamera_dev – jessie
When I try to grab the package it just says it can’t find the corresponding package. It literally prints something like:
“Cannot find the corresponding package, please send the following information to [email protected]”
So that’s why I ended up here.
Thanks, that helps a lot. That message is just the installer telling you it couldn’t match a package for your OS.
Quick question: have you tried installing libcamera-dev directly, e.g. sudo apt-get install libcamera-dev? And if so, what does it return? Also, when you say you tried to download the library for rb-camera-ww, can you describe exactly what you did (script, apt, manual download)?
I tried a couple of things. I ran the install for the rb-camera-ww library and it failed. I also tried installing libcamera-dev on its own and that didn’t work either. The error basically points me back to the package not being found for my system. I’m on jessie, kernel 4.4.21-v7+, if that matters.
Yeah, that’s the key detail here. Looking at what you posted:
- Kernel 4.4.21-v7+
- OS: jessie (and Buster is the same story for us)
Your OS release is quite old. libcamera-dev and the newer camera stack need a much more recent base. The packages simply aren’t available for Jessie/Buster anymore, which is why the installer can’t find a matching package. It’s not something you did wrong.
The root cause is the outdated OS version. Arducam no longer maintains the old Buster/Jessie releases, so any libcamera-dev style install will keep failing on those.
Ah, okay, that makes sense. So what should I do – is there any way to make it work on my current jessie install, or do I have to start over?
Easiest path: don’t try to patch the old OS. Burn a fresh image of the latest Bullseye and use that instead of your old Jessie/Buster install. Reflash the SD card with the current Bullseye image, boot it up, and then the camera library/libcamera-dev install will go through normally.
Jessie and Buster are effectively end-of-life for us, so there’s no maintained package path for them anymore.
Got it, I’ll reflash with Bullseye and give it another go. Thanks for the explanation, at least now I know it wasn’t my setup.
No problem. Quick recap for anyone else who lands on this thread:
- Symptom: libcamera-dev (and the rb-camera-ww library) fails to install, installer reports it can’t find the corresponding package.
- Environment seen here: Hardware Revision a02082, Kernel 4.4.21-v7+, OS Jessie (Buster is also affected).
- Cause: the OS release is too old – Arducam no longer maintains the old Buster/Jessie versions, so the required packages aren’t available.
- Fix/workaround: reflash with the latest Bullseye image and install from there instead of the old Jessie/Buster install.
I’ll also double-check on my side and follow up if anything else comes up. Thanks for your patience while we worked through it.
