Hi everyone, hoping someone can point me in the right direction. I’ve got an Arducam PTZ Pan Tilt Zoom Camera (B0167B12, the 12MP camera with the rotating base) hooked up to a Raspberry Pi. I’m trying to run FocuserExample.py, but it can’t detect the I2C device and fails with:
[Errno 121] Remote I/O error
I’ve been messing with this setup for a while now, and I also have a feeling the middle daughter board control is acting up. I’ve seen a few people report the same thing online, and some have said it could be a factory daughter card problem. Anyone seen this before?
Thanks for the details. A [Errno 121] Remote I/O error on the I2C bus is very often power-related before we jump to a board fault. What power supply are you using for the Raspberry Pi? Could you share the voltage and current rating?
Please do. For reference, the recommended supply for the Pi with this PTZ module is 5V 3A. If you’re on a 2.5A supply, or a battery that can’t sustain the current under load, the camera and motors can drag the rail down and the I2C device drops off - which shows up exactly as that Remote I/O error.
Got the photo, thanks. Since you’re on a battery, my first suggestion is to try a proper 5V 3A wall adapter if you have one available, just to rule out power sag. I’ll review the photo and the info you provided and follow up with you.
Just following up - it’s been a little while now. Any update on next steps? I’d like to know how to proceed, especially if it does turn out to be the control board.
Apologies for the wait. I’ve reviewed the power photo and the test details you sent over. Based on everything so far, this looks like a hardware fault on the PTZ module’s control board rather than a software or power-supply-only issue. The I2C bus isn’t responding properly, so the control board itself will need to be replaced.
