Amazon
UC733 usb3 cam board
Pi 4
The PDFs you provide and YouTube vudeos
Never worked
I’m trying to get my hq pi cam to work on a pi over USB. This is just temporary until our actual target SBC shows up where we’ll deploy Ubuntu.
I cloned the USB breakout repo and tried to run the Python code. It told me I had to install the config parser so I also cloned that and installed it per the readme. I’m still getting the same error when I try to run the code in python3:
load libarducam_config_parser failed. Make sure you have it installed. Libarducam_config_parser.so: cannot open: no such file or directory.
Please provide detailed instructions of how to install and use required software to use a IMX477 cam via USB
