Can I use only 2 cameras on the Arducam quad camera hat for Jetson Nano?
Hi everyone, quick question. I’ve got an Arducam quad camera hat on my Jetson Nano. My project doesn’t actually need all 4 cameras — is it possible to run just 2 cameras on this hat? I’d rather not buy a separate dual camera hat if I don’t have to.
Yes, that’s supported. The quad camera hat can run in dual-channel mode so you can operate with only 2 cameras instead of all 4. Can you tell me a bit more about your current setup and what you’ve tried so far?
Right now the Jetson is powered on and it’s detecting all 4 cameras. I just want to bring it down to 2, but I’m not sure where the mode actually gets changed. If it’s easier to look at it directly, I can set up remote access — I’ll send you the details through a private message.
Thanks, I got your remote access details via private message. Based on what I can see, this isn’t a hardware fault — it’s just a configuration question about running fewer cameras than the quad hat supports. The hat has a dual-channel mode which is exactly what you want when only 2 cameras are needed.
Okay, that makes sense. So where do I actually switch that? Is it a jumper on the board, or something I change in the device tree or driver config?
It’s done by switching the composition mode on the hat. The Arducam docs cover this in the Multi-Camera CamArray quick-start guide, under the ‘Switch composition mode’ section: Quick start - Arducam Wiki — follow that section and select dual-channel mode for 2-camera operation.
That worked. I switched it to dual-channel mode following that guide and now it’s only initializing 2 cameras. Thanks for pointing me to the right section.
Glad that sorted it. Just to wrap up: the quad camera hat supports dual-channel mode for running only 2 cameras, and switching the composition mode using the linked Arducam CamArray quick-start guide is the way to do it. Nothing was faulty with the hardware — it was purely a configuration change.
