Can I share the Sync Stereo Camera HAT I2C pins with another HAT?
Hi Arducam Support Team,
Can i share the Sync Stereo Camera HAT I2C pins with another HAT?
I have a RPI3B+ with default configuration: I2C on GPIO2-3, i2c-1 channel on the same pins and WiringPI library for controlling th I2C bus. I have different modules and hats that uses the same I2C pins than the Sync Stereo Camera HAT but in a different channel. Will I have problems if i want to use my modules and hats at the same time than a Sync Stereo Camera HAT?
Many thanks.
If the i2c address is different, you can share the same i2c bus. If the address are the same, it will respond to the master at the same time.
